Re: Multi-team?
STIMS won't allow you to register for more than one team, but I don't recall any rule specifically stating that you cannot actively participate in multiple teams in the same FIRST program.
Re: Multi-team?
Adding to this, I recall some teams having to leave regionals early (weather hazards) and requiring substitute drive teams due to school policy in an effort to not get disqualified. So, while technically possible, it is extremely rare under specific circumstances.
Re: Multi-team?
Re: Multi-team?
I would not go into an event planning to have someone from another team on your drive team, unless you knew that a religious holiday or major testing was going to be a factor and was unavoidable. Especially with that "may" in there--that makes it clearly discretionary on the part of the event staff (though those folks are generally accommodating). |
Re: Multi-team?
Re: Multi-team?
You would likely have to pick one team or the other for the entire competition and not switch during that time.
#7
Re: Multi-team?
If you ever find a way, i also have concerns with always having a different drive team for each match...
#8
Re: Multi-team?
Re: Multi-team?
Then again, that person has to be registered on your team via STIMS to be eligible on your drive team If you already have one specific person in mind, then you could arrange that right now and have him/her register in your team
#10
Re: Multi-team?
Just found out that on the printed roster from TIMS we could manually add students... So, even if the student doesn't join the team via STIMS, can we add them this way?
#11
Re: Multi-team?
Sorry for upping this again... Just wanted to add that I received a confirmation email from FRC telling students can officially be on two teams... We only need a written confirmation for the student list...
#12
Re: Multi-team?
As I understand it, all FIRST competitions are open to the public, so anyone can wander in, and even work on another team's robot in the pits. It happens all the time, and we even awarded our GP trophy last year based on one of our team member's hours spent working in a rookie team's pits. There are only a few specific functions which require someone to be a member of the team. Student drivers and HPs are definite cases, and while I haven't checked the rules specifically, I recall that questions and challenges, chairman's award presenters, and representatives in the alliance selection process are also required to be team members.
#13
Re: Multi-team?
Re: Multi-team?
For the record, I have heard of a single-student team competing before, with much support. A short-handed team can be supplied. But, if I was structuring a drive team and knew that I might be shorthanded, I'd start by trying to remove the second robot operator (if possible due to robot structuring), then the coach. HP can act as coach if they aren't HP'ing (but the reverse is not necessarily true). For mentors (not students), it's a whole lot easier, I must say. Mentors can be on multiple teams in FIRST's records. |
#15
Re: Multi-team?
