Go to Post We're not all autonomous robots who are preprogrammed to always follow rules blindly regardless of what they are. - Ryan Dognaux [more]
Unread 31-10-2015, 13:41
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
pic: Follower Wheel
Unread 31-10-2015, 13:46
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Follower Wheel
That looks beautifully integrated! any reason why you chose to use the large gear on top instead of a small gear and a multiplier in code?
Unread 31-10-2015, 15:35
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Probably so it would clear the encoder. VEX gears increase in size in 1" increments.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 02-11-2015, 02:44
JackFisher's Avatar
JackFisher JackFisher is offline
JackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud of
Do you have a sort of spring to keep it driven into the ground? Also, be very careful in making sure it deploys 100%. 973 used them in 2013 for their 6wd and in quarterfinals at champs, 1 follower wheel didn't deploy and that cost us the match. Don't want your team to learn that the hard way.
Unread 02-11-2015, 08:00
FRC #2791
Jay is right, two 60 tooth gears are the smallest stock gears to clear the wheel and encoder. We may try to 3d print a smaller gear, but the additional distance between gears also allows for more material to hold the frame together.
Yes, we would either use a rubber band or use a spring to make sure it is down. It always be deployed, we would just need to make sure that it moves smothly. Once we make a bracket to attach it, we will see how smooth it is. We may need to make some adjustments, but it shouldn't be too hard to make it move smoothly.
Unread 02-11-2015, 13:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
How wide is it at the widest point? Wondering if it'd fit between a WCD frame and the bumper.
Unread 02-11-2015, 15:24
FRC #2791
The widest point is 2.25".
