Go to Post Coming soon to an Earth near you; an Australian team (or 2). Stay tuned. - Elgin Clock [more]
Unread 23-10-2015, 08:06
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
I2C issues
We are having trouble getting an andymark am-2314 accel/gyro unit to send data on the i2C network. This is our first time using I2C are not sure if we are having a code or hardware issue. We have been working with the ADXL-345 to start with, but the real goal is to get the gyro working.
The unit is wired 3.3V to 3.3 V, ground to ground, SCL to SCL, and SDA to SDA. We also have a 4.7k pullup resistor between SCL and 3.3V. We checked that all connections are good and there are no shorts. We are measuring 3.27 volts into the 2314, so we know the I2C port on the roborio has power.
Any advice would be appreciated. Thanks!
The JAVA code looks like this:
package org.usfirst.frc.team1493.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.I2C;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import java.nio.ByteBuffer;
import java.nio.ByteOrder;
public class Robot extends IterativeRobot {
// 0x1D is the default accel address, 0x53 is the secondary accel address
// 0b1101000 is the default gyro address, 0b1101001 is the secondary gyro address
private static final byte kAddress = 0x1d;  // also tried 0x53
private static final byte kPowerCtlRegister = 0x2D;
private static final byte kDataFormatRegister = 0x31; // also trued 0b100
private static final byte kDataRegister = 0x32;
private static final double kGsPerLSB = 0.00390625;
private static final byte kPowerCtl_Link = 0x20, kPowerCtl_AutoSleep = 0x10, kPowerCtl_Measure = 0b1100;
private static final byte kPowerCtl_Sleep = 0x04, kRange = 0x00;
private static final byte kDataFormat_SelfTest = (byte) 0x80, kDataFormat_SPI = 0x40, kDataFormat_IntInvert = 0x20;
private static final byte kDataFormat_FullRes = 0x08, kDataFormat_Justify = 0x04;
I2C I2CBus = new I2C(I2C.Port.kOnboard,kAddress);
double accel[] = new double[3];
    public void robotInit() {
// Turn on the measurements
//also tried this
// I2CBus.write(kPowerCtlRegister, 0);   //kPowerCtl_Measure);
// I2CBus.write(kPowerCtlRegister, 16);   //kPowerCtl_Measure);
// I2CBus.write(kPowerCtlRegister, 8);   //kPowerCtl_Measure);
I2CBus.write(kPowerCtlRegister, kPowerCtl_Measure);
I2CBus.write(kDataFormatRegister, kDataFormat_FullRes | kRange);
    public void autonomousPeriodic() {
    public void teleopPeriodic() {
       accel = getADXL345Data();
    public void testPeriodic() {
    public double [] getADXL345Data(){
    short x_axis,y_axis,z_axis;
    double acceleration[] = new double[3];
    byte buff[] = new byte[6];
    I2CBus.read(kDataRegister,6,buff);
// also tried this to convert from bytes to integer
//    ByteBuffer convbuffer = ByteBuffer.wrap(buff);
//     convbuffer.order(ByteOrder.BIG_ENDIAN);
//     x_axis = convbuffer.getShort();
//     y_axis = convbuffer.getShort();
//     z_axis = convbuffer.getShort();
    x_axis = (short)((((int)buff[1])<<8) | buff[0]);
    y_axis = (short)((((int)buff[3])<<8) | buff[2]);
    z_axis = (short)((((int)buff[5])<<8) | buff[4]);
    acceleration[0] = x_axis * kGsPerLSB;
    acceleration[1] =  y_axis* kGsPerLSB;
    acceleration[2] = z_axis * kGsPerLSB;
    Timer.delay(0.050);
SmartDashboard.putString("DB/String 0", "buff0 " + (int)buff[0]);
SmartDashboard.putString("DB/String 1", "buff1 " + (int)buff[1]);
SmartDashboard.putString("DB/String 2", "buff2 " + (int)buff[2]);
SmartDashboard.putString("DB/String 3", "buff3 " + (int)buff[3]);
SmartDashboard.putString("DB/String 4", "buff4 " + (int)buff[4]);
SmartDashboard.putString("DB/String 5", "buff5 " + (int)buff[5]);
SmartDashboard.putNumber("DB/String 6",   x_axis);
SmartDashboard.putNumber("DB/String 7",   y_axis);
SmartDashboard.putNumber("DB/String 8",   z_axis);
// check if we are getting to this method
// SmartDashboard.putString("DB/String 8", "scale "+(int)(kGsPerLSB*1000));
    return acceleration;
Unread 01-11-2015, 09:11
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Re: I2C issues
We are a Labview Team, so I am going to be of limited help. For Labview, there are a large number of examples, and one of them is for the ADXL. If there are also examples provided in JAVA, then you may be able to narrow down the possible issues. I suppose you could also install the Labview environment and use this one example to narrow down your problem to code or hardware.
