Go to Post the bang for the buck is unparalled. Where else can $6000 change an entire group of student's lives forever? - Cory [more]
Unread 01-11-2015, 17:12
traxxasracr1's Avatar
traxxasracr1 traxxasracr1 is offline
AKA: Blake Hobbs
FRC #3255 (SuperNURDs)
Team Role: CAD
traxxasracr1 will become famous soon enough
pic: Inverted 3 CIM 2 speed gearbox with PTO
Unread 01-11-2015, 17:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Inverted 3 CIM 2 speed gearbox with PTO
Looks nice! How does it mount to the chassis?
The one thing I would caution against is that if you gear 6 cims that high, you're liable to brownout the RoboRIO.
Unread 01-11-2015, 19:59
JoshWilson's Avatar
JoshWilson JoshWilson is offline
FRC #0230 (Gaelhawks)
JoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to all
Very nice, I like it!
Unread 01-11-2015, 20:27
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Oh brownouts...
I'm not sure what is going on with beta testing, but for the 2016 year, is there going to be a fix for this?
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 01-11-2015, 21:21
AKA: Blake Hobbs
Team Role: CAD
Yeah, we have the bownouts in mind, thats why we want to experiment with this much power now so that we dont have to troubleshoot during build season. We want to try to implement some auto shift code to try to eliminate some human error. So if anyone has any input on auto shifting, please share. As of right now, I dont know if it would be best to put the encoder on the motor side of the gearbox, or the wheel side. (reading the speed of the motor vs. reading the speed of the wheel because it will change with shifting). Also, the gearbox mounts with 2 1/4-20 screws going through the 1/8 wall of the tubing on the frame, with the hex shaft mounted permanently to the frame, and just going into a female hex on the ball shifter, allowing the gearbox to come off without removing any axles.
Unread 01-11-2015, 22:43
Jared's Avatar
Jared Jared is offline
I really like this design - having a quick swap gearbox is useful.
We did the same thing in 2014 with a 3/8" female hex made from a steel hex sleeve from SDP. There are two things to consider with this type of design: the gearbox flexing away from the frame and the alignment of the output shaft with the wheel shaft.
The fit of our female hex was sloppy, so we definitely needed two bearings on the gearbox shaft and two bearings on the wheel shaft. Getting the alignment of these four bearings is crucial for this design to work. The same applies for the mounting holes, but these could always be slotted if alignment is an issue. We had issues at first when we were using Vex hex shaft that was bent. As of 2015, the shafts are MUCH better, but there are still two very different versions of the hex shaft sold by Vex.
Your setup to hold CIMs will help decrease the moment on your center plate, but there will still be a moment on the 1/4-20 bolts and the wall of your tube. Be aware that different CIMs have different OD's. The wall of the frame tube is pretty thin, and I'd be worried about the holes being enlarged or the wall being bent, though I have heard of teams getting away with a setup like you have. We welded inserts into the frame rail that were connected to both walls of the frame tube, but this may have been overkill.
Unread 02-11-2015, 00:44
Knufire Knufire is offline
You might have some trouble shifting that PTO depending on what it's powering. We coupled a 1.5" or 2" bore (can't quite remember) to a ball shifting shaft on our winch in 2014 to engage/disengage a ratchet and it often had problems shifting as the cylinder induces a bending moment on the shifting rod. No idea if you'll see the same problems with the smaller cylinder, but making sure the coupler is as stiff as possible will help.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 02-11-2015, 02:20
JackFisher's Avatar
JackFisher JackFisher is offline
JackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud of
Do you think the extra plate for supporting the cims is really necessary? Adds a lot of parts and tolerances.
Unread 02-11-2015, 09:17
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
You said you guys are going to test for brownouts. Are you going toramp up the speed until you achieve the brownout or up to a speed conducive with an event type environmnent?
Team member 2004-2008
Team mentor 2008-2014
http://team1708.steelcityrobotics.or...tics/Home.html
"12 years as a student and mentor and proud of it"
Unread 02-11-2015, 09:21
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Originally Posted by KohKohPuffs View Post
Oh brownouts...
The brownout behavior is a fix for the roboRIO and other electronics rebooting if voltage gets too low. It is a safety precaution that triggers when you are asking more our of your system than it can reasonably provide. The brownout is there to keep the user from doing something they shouldn't to the electronics. Generally, a brownout is better than radio reboots or rio reboots.
Unread 02-11-2015, 12:36
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Eh, only 3-5 extra parts.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 02-11-2015, 18:38
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
It looks like the third plate is for mounting and giving the cylinder for the PTO some wiggle room.
It isn't shiny enough.
Unread 02-11-2015, 20:46
AKA: Blake Hobbs
Team Role: CAD
we haven't had any problems with alignment between the plates in the gearbox, but I do like the idea of slotting the holes, we will consider that if we have problems later on.
Unread 02-11-2015, 20:49
AKA: Blake Hobbs
Team Role: CAD
We have the piston attached to a 1/4 plate that's only an inch long, so I don't believe flexing will be much of an issue. We did this same type of shifting on our lift this year and didn't run into any problems.
Unread 02-11-2015, 20:51
AKA: Blake Hobbs
Team Role: CAD
The extra plate is only one extra part, and it keeps the motors from sagging outwards, if we find that it isn't necessary and becomes a hassle, we can just simply remove it and make the final hex shaft shorter.
