Originally Posted by asid61
That looks beautifully integrated! any reason why you chose to use the large gear on top instead of a small gear and a multiplier in code?
Originally Posted by Jay O'Donnell
Probably so it would clear the encoder. VEX gears increase in size in 1" increments.
Jay is right, two 60 tooth gears are the smallest stock gears to clear the wheel and encoder. We may try to 3d print a smaller gear, but the additional distance between gears also allows for more material to hold the frame together.
Originally Posted by JackFisher
Do you have a sort of spring to keep it driven into the ground?
Yes, we would either use a rubber band or use a spring to make sure it is down. It always be deployed, we would just need to make sure that it moves smothly. Once we make a bracket to attach it, we will see how smooth it is. We may need to make some adjustments, but it shouldn't be too hard to make it move smoothly.
