Go to Post Gracious professionalism is competing with a team one minute, and helping them fix their robot the next. It is cheering for FIRST, rather than just your team, and most importantly: it is looking at the future and saying, "Together, we can do that" - WakeZero [more]
  #31   Spotlight this post!
Unread 02-11-2015, 12:54
Knufire Knufire is offline
Re: New Products for 2016: Speculation, Wants
Originally Posted by Foster View Post
If you Google "electrical slip ring wind turbine" you get a pretty good selection of choices. They are all for low speed(~250 RPM), I don't know what your application is. I also assumed that you were not trying to transfer any load though them.
I assume his application is to power a CIM on a swerve module and get full rotation without a coaxial power transmission setup.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #32   Spotlight this post!
Unread 02-11-2015, 12:55
Joining the 900 Meme Team
FRC #0079
The one I used is made by Moflon, three wires, 30Amp and cost me about $30. MW1330 is the model I have. As always your mileage will vary.
If you are after just doing control signals, Adafruit has some low voltage, low current ones. 2A / 6 wires ~$15 plus shipping.
I've got one similar to your 30A one. The big issue is that means I'd have to run CIMs on a 30A breaker since the slip ring is only rated to 30A. It's for 16 style swerve modules. And getting rid of the extra wire would help them be lighter.
  #33   Spotlight this post!
Unread 02-11-2015, 13:14
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Speaking of VersaPlanetaries, I'd love to see a longer 1/2" hex output shaft for the VersaPlanetaries...say 6-8".
I second the need for a Banebot wheel alternatives/replacements...smooth tread, 1/2" hex bore, differing durometer materials, really cheap, and larger than 2.5" diameter.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
  #34   Spotlight this post!
Unread 02-11-2015, 13:23
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Would love to see VersaWheels with the "W" tread pattern in a 3.25" size. Image of the tread pattern:
http://www.vexrobotics.com/media/cat...1/217-2903.jpg
  #35   Spotlight this post!
Unread 02-11-2015, 13:53
Oblarg Oblarg is offline
AKA: Eli Barnett
Originally Posted by JesseK View Post
We have noise on Versaplanetaries when the pinion isn't seated/mounted correctly. The pinion attachment either rubs the motor plate or it rubs the opposite gear/plate. It really pays to pay close attention to the text in the instructions when assembling these things.
Before we apply power, we use a hex hub to reverse-drive the motor by hand. If there's any binding or chattering, we disassemble and reassemble. It should be smooth-running in both directions (caveat - we've only done 2-stage, up to 49:1).
I haven't actually assembled any myself, but I'll try to oversee the next time one gets put together and pass this on in case they've been doing it sloppily. Thanks.
"The breakfast of champions!"
  #36   Spotlight this post!
Unread 02-11-2015, 14:33
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
We've used versaplanetaries both this year and last. The only had issues we had were some pins in the carrier plate were not flush on one side which caused friction and binding. This was fixed by an arbor press to make the pins flush.
461 Westside Boiler Invasion
45 Technokats
  #37   Spotlight this post!
Unread 02-11-2015, 15:00
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
More or less in order of importance...
1. More VexPro gear sizes. We have a pretty good variety of 1/2 and 3/8 hex gears, but I'd particularly like to have 18, 22, 28, and 32t gear options. Really, it'd be ideal to have every even gear tooth count from 14 - 70t available... we aren't too far from it, but somehow lacking those few missing ones feels limiting when designing custom shifting gearboxes. It'd also be nice to have a few more sizes of Ball-Shifter gears... 40t, 46t, and 56t especially... although I suppose some might like 64t too. Instead of really only having a few 10t and a 16t pairing to choose from (34-44, 44-54, 44-60, and 50-60), we'd have more 10t splits along with some potentially really nice 12t and 14t ones (40-50, 40-54, 44-56, 46-56, 46-60, 50-64, 54-64). A few more sizes in the 80+ tooth range with VersaKey/Bearing Bore mounting would be icing on the (cheese)cake...
2. Seconding the 'VersaPlanetary Encoder Block' suggestion. Our team uses more motors with encoders than without (I think only 2 of the motors on our 2013-2015 robots didn't have encoders)... having to design in encoders can often be tedious or unnecessarily constrain the design.
3. Longer options for the Ballshifter output shaft (even if it was just the .5" hex shaft and we'd install them separately... perhaps that'd be preferable anyway?)
Really though, I'd like to thank AndyMark and VexPro for what they've been doing over the past few years to supply good options to designers experienced and inexperienced to make it easier to do the 'ordinary' and the extraordinary. The selection of COTS frames, wheels, gearboxes, and the various 'building blocks' like hex and tube shaft, hub adapters, gears, etc. is truly fantastic! And even while the selection has broadened, the prices have become lower too!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
  #38   Spotlight this post!
Unread 02-11-2015, 15:10
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
One specific extra ratio would be nice as well. A 27T 3/8 Hex gear, and then 47T 1/2 Hex and Dog Gears. This would give a nice in between ratio for the WCP gearboxes, that would be fantastic at about 13 FPS.
One other thing I would like to see is a COTS Disk Brake. The Poofs brake from this year seemed very simple, and it seems like it would be pretty easy to make COTS.
Team 4488 - Mentor 2013-2016
  #39   Spotlight this post!
Unread 02-11-2015, 15:15
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Since this is turning into a wish list thread:
More support for 1/2" keyed round shafts. Not every team owns a hex broach, and 1/2" round axles often match what is available from non-FRC suppliers. Many products have this option available, but not all do, and we end up having to purchase hex hubs to accommodate those products in our design. Last year that turned into a significant delay as we waited for the hex hubs for the Colson wheels we were mounting directly on our WCP transmissions. The rest of our wheels were mounted without that delay, since we used 1/2" keyed. This can often go hand-in-hand with the hex shaft and hex bearing shortages we see during build season.
  #40   Spotlight this post!
Unread 02-11-2015, 16:57
page2067's Avatar
page2067 page2067 is online now
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
A 3/8" hex bore bearing with a 0.875" OD.
  #41   Spotlight this post!
Unread 02-11-2015, 17:10
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Chain tools for 35 and 25 chain similar to this one:
http://www.parktool.com/product/chai...category=Chain
Sprockets for bike chain. (cheaper, more available, lighter and more resistant to misalignment than #35 chain. If you get the unreasonably expensive stuff it's even lighter than #25 while being considerably stronger)
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
  #42   Spotlight this post!
Unread 02-11-2015, 19:02
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Chain breakers are already commonly available. You can even find tools that can re-peen the old pin like this one from 221 Systems or this one.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #43   Spotlight this post!
Unread 02-11-2015, 19:55
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
This is probably being picky, but a 3 CIM Ball Shifter WCD with Native support for two 15mm pulleys would be great!
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
  #44   Spotlight this post!
Unread 02-11-2015, 20:39
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Personally, I am looking forward to the long-awaited adoption of unobtanium as a primary material for all items. This is a long awaited and much needed change in my opinion.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #45   Spotlight this post!
Unread 02-11-2015, 21:56
REVving up for a new season
FRC #2848 (All-sparks)
Originally Posted by Daniel_LaFleur View Post
I'd love to see an electronic pressure controller or electronic variable pneumatic regulator.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
