Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 03-11-2015, 23:47
AdamuKaapan's Avatar
AdamuKaapan AdamuKaapan is offline
FRC #3268
AdamuKaapan is an unknown quantity at this point
Where to buy twisted CAN cable like KOP?
Hello, I've been looking for something like in the KOP where we got twisted green and yellow cable. I've found individual wires, but I have yet to find cable that is already twisted, the right size, and the right color all in one.
I know that we could twist it ourselves or use the wrong colors, but I'm curious to see if anyone's found a simple way to order this already "assembled".
Thanks!
- Adam, Team 3268 -
Unread 03-11-2015, 23:51
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Where to buy twisted CAN cable like KOP?
http://www.ctr-electronics.com/can-bus-cable-10ft.html
R.C.
MadTown Robotics Team 1323
Unread 04-11-2015, 00:39
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Jameco has roles of twisted pair 24 AWG wire in 100 and 1000 ft lengths. We liked the green and white twisted pair. :-)
http://www.jameco.com/webapp/wcs/sto...0001_105912_-1
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 04-11-2015, 08:03
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Cat 3 pairs are the right gauge and have the right number of twists. Someone donated the school spools of the stuff a while back, and we grabbed a few feet. It's cheap, as it's going out of style. If you use the Talon SRXs, you may not need to use any wires other than the ones embedded in the motor controllers; just put the Talons electrically between the devices with the clips.
Unread 11-11-2015, 02:18
FRC #3268
Ah, thanks a lot @R.C. That's exactly what I was looking for (I'm blind apparently). Thanks!
Unread 11-11-2015, 04:16
R.C.'s Avatar
No worries I just found it a few weeks ago, seems like CTRE recently added it!
R.C.
Unread 12-11-2015, 09:54
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
You can always twist your own. Just attach the wire to a drill, have someone hold the other end, and twist away. Go slowly and be safe!
Unread 12-11-2015, 11:59
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Would it stay like that if there wasn't something holding it twisted? IIRC wire comes untwisted pretty easily. And if the only thing holding it twisted is the electronics then I imagine the twisting would pull the wires out easier than otherwise (especially with the CAN Weidmeuler connectors that come out so easily).
Also that sounds like it could be very unsafe if not done with the utmost care.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 12-11-2015, 12:10
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We've done this in the past, and it works very well. Sure, when you release the tension it loosens up a bit, but once you get past that it stays twisted without anything else holding it. It's just like bending a piece of sheet metal - you bend it, it relaxes a little bit, then holds that new shape forever. Trust me - we have wires sitting in boxes that are still twisted together and probably haven't been attached to anything for years. The kids seem to think that any wire with a 5 cent connector on it should be saved, because we "might need it later".
2016: Lake Superior WFFA
Unread 12-11-2015, 12:35
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If you twist your own wires (or make your own rope), you'll want to keep the angle of attack of the strands with the place that is being twisted essentially constant as you twist. You should also proceed at a steady speed, with steady tension. This helps ensure that the wire is twisted evenly along its length. The tighter you want the twist, the wider the angle would be. The angle shown below is too steep for CAN wires, but it shows the idea.
   \____
 \______
\_______
Unread 12-11-2015, 12:50
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Stranded cat3 would be fine; be careful about using solid cat3 wire, as the wire can develop stress fractures due to vibration. Wiring in airplanes and automobiles is almost exclusively stranded wire for this reason.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 12-11-2015, 13:15
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
note my handle ;o), use wireties on each end to make sure it does not unwind
this is no more dangerous than using a drill for anything else
good luck!
Unread 19-11-2015, 08:16
When twisting your own wire, a simple technique works very well. One student holding the drill, two students holding the opposite end of the wire and one student following the twist with their fingers. The students at the far end of the wires, should allow the wire ends to spin naturally in their hand. The student walking the twist should lightly clamp the twist in their fingers. This will set the wire as you twist. #22 wire works very well for this. You are trying for about 1-2 twists per inch. As a final step, chuck one end of the pair in a bench vise, and then stretch the wire out and give it a good pull. That will stretch the wire a little and set the twist. Taking this last step will prevent the wire from self twisting and kinking up as well preventing it from untwisting. We generally will twist about 30' at a time.
Unread 19-11-2015, 08:48
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not completely on topic... 10 feet twisted pair in the KOP would cover most teams needs fo canbus.
