110ft/s (75mph) robot design
Awhile back, I saw team 868's Totebot, a robot in a tote that drives at 50mph. I was inspired by their video to design a robot that can go as fast as possible using only FRC legal parts.
I have named the design: Sanic It has 6 cims, geared at 34-50 at low, and 50-34 at high. achieving 35mph and 75mph respectively. Amazingly, the math all works out, for the amperage at least. By limiting the amperage for each cim at startup to 40, and then bumping it up to around 50 when shifting to high, it can reach 75mph without the 40 amp snap action cim breaker, or 120 amp main breaker popping. It comes very darn near to dying, but it doesn't. I'm not a electronics guy, so I'm not sure if there is anything else that will go wrong (there probably is) except for the roboRIO browning out, if that is the correct term. Of course, this isn't something that I will ever build. It was a fun thought experiment, and a challenge, to see how far I can push the equipment that we have. And before anyone asks, no. I don't have a way to stop it. Thoughts? Questions? I would love to hear what the community thinks of a crazy design such as this. |
Re: 110ft/s (75mph) robot design
Did you use the JVN Design calculator to figure your expected motor currents with that configuration? Although I don't have the other specs that I need of your design (wheel diameter, weight on wheels), I did some guessing and the resulting "pushing match" current (in this case accelerating from 0) runs up to 152 amps per motor. |
How much runway and time do you calculate that you'll need to reach top speed?
Could I get a picture of the gearboxes (and cims) only. I'm very intrigued.
I don't have the time to check your other points... but the CIM can draw "only" 133A at stall...
wheel diameter is 4in weight is around 50lbs (the 10lbs for electronics is added in, but not shown) the pushing match current is if you are pressed up against a wall. in which case, this drivetrain is more then likely power limited which is why the current drawn is so high. Quote:
i'll post all of my calculations when i get home. Last edited by Aaron Ng : 11-05-2015 at 11:21 AM. |
#7
Hey Aaron, carpevdav000 has a rather appropriate signature for this thread:
(We have a similarly "creole" unit system here) |
#9
I think you may be going a little overkill with the motors there.
![]() If you want something to go fast (as in, high speed, not high acceleration) then you just need enough power to counteract the drag you would see at that speed. Getting rid of drag is just as good as adding power. I would suggest focusing more on a small profile robot with a gearing system that lets you go through a wide range of ratios. With the size of the components, I don't think you'd need more than 1 CIM to power it if it was in an aerodynamic shell. Also, you should get rid of that 6wd tank style steering system... It works good when you are driving a robot around small spaces on an FRC field, but you won't be able to control a fast moving robot with it very well. Cars use Ackermann style steering because it's easy to control when you're driving down the road. |
#10
Aaron, you've inspired me to think more about this concept... make as fast a robot as possible with 'ordinary' FRC parts. I think this'll be a design project for me for a while. :-)
Having thought about it some, I think a good design would probably look a fair bit more different from the typical FRC robot than your design does. Quote:
Your weight seems a little low for including electronics and battery... are you including both? Because I think it'll take a substantial percentage of the time to cover the final 25mph, I suspect the 75m may be quite low. This will definitely not accelerate linearly. |
#11
I'd use one of those fancy internal hub shifting things that are used on bikes to get tons of different gear ratios. I'd also use two batteries with two main breakers.
#12
Yes, looking back, more shifting speeds would definitely be more optimal than my solution of more motors. Less stress on all the other electronics while being lighter. However, the reason for all the motors is that it has to start and stop within a 200m runway, as that is the longest we have at school. An artificial restraint, of course, as we won't build it, but was definitely a fun, additional challenge for me. Would more stages compensate for lower power? I don't know how to design shifters, but I’m thinking of having two or even three shifters next to each other. The idea behind the tank drive was that the track at school has a turn in the beginning, so for the first, perhaps 70m I will be turning while accelerating. I was thinking of sticking my swerve design on the front, and taking out the CIMs, (is that what turntable is?) but the extra weight stopped me. Ackerman steering sounds quite difficult to design as well as build. I was thinking a simple caster, but traction may become a factor. The reason for the smaller wheel was all because of weight. not only is the wheel larger, but now I need a way to mount the wheel above the drivetrain as I would think that keeping the robot as low as possible would be the best. But perhaps I am wrong on that point. The weight is that low because everything is made from 1/16. That is also how I got an 18t sprocket to work. We have custom weights on most COTS parts, and solidworks estimated everything to be around 40lbs (with battery). I’m guessing that the electronics and chain would add another 10. Thus, 50 Wow! That just tore my design completely to pieces. My calculations were all done in an ideal world. No voltage drop, no air resistance, etc. I did calculate air resistance, but only at 75mph, and with a lot of guessing, since that is the extent of my knowledge in physics. So I guess that this design is no longer an "it might work in theory" but rather an "it will probably crash and burn in theory". Though I won’t be working on this for quite a while. It has already taken up enough of my time that I was dedicating to college apps. My calculations are as follows: Amperage and pushing strength at taken from JVNcalc Pushing strength at low gear, with motors limited to 40amps is 27lbs or 120N F=MA 120=22.68A A=5.29m/s^2 Pushing strength at low gear, with motors limited to 40 amps is 13lbs or 57.8N F=MA 57.8=22.68A A=2.55m/s^2 Vf=Vo+At 15.64=0+5.29t t=2.96s 33.5=15.64+2.55t T=7s 7s+2.55s=9.55s 120 amp breaker pops in 10s when under 200% load, Of course, this is all in a ideal world. So irl, it probably won’t be as nice as this. Acceleration drops over time, but amperage does as well. Is that enough to stop parts from dying? Im not sure. Quote:
#13
This is the sort of shifting transmission I was thinking about. Somebody made a cool battery powered tricycle using an 8 speed one that could get going pretty quickly. |
#14
If you were going to use a bicycle hub transmission, get something like a shimano alfine 11. . Just make sure to cut the current during the shift, because the won't shift under full torque. |
