Go to Post Parking Lot T-Shirt Bootleggers are NOT approved suppliers - Rich Kressly [more]
Unread 05-11-2015, 19:47
TheChosenOne TheChosenOne is offline
FRC #5190
TheChosenOne is an unknown quantity at this point
Exclamation Can Talon SRX Reverse The Slave
Hey, I am trying to reverse the output of the slave motor using a master and slave configuration. I can get both of the motors to run, but I am not completely sure about why the slave doesn't reverse. I looked it up in the Talon SRX Software Reference Manual and it said to toggle the Revere Closed-Loop Output but it didn't do anything.
Our Setup:
Master Motor: On CAN with device number of 11 and has a analog potentiometer connected to it.
Slave Motor: On CAN with device number of 12 and has no encoder connected to it.
ID:	19397  Click image for larger version
Unread 05-11-2015, 21:58
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Can Talon SRX Reverse The Slave
Add a terminating SetOutput(0) to the signal chain in Begin.vi. It's better explained in Section 21.20 of the Talon SRX software reference manual. Also this limitation won't exist in the FRC2016 season.
Unread 13-11-2015, 16:12
cmoon71 cmoon71 is offline
AKA: Chuck Moon
FRC #3015 (Ranger Robots)
cmoon71 is an unknown quantity at this point
Re: Talon SRX CAN closed-loop multi-motor options
Using a single PWM signal using a 3-wire Y-Cable, 2 or more Talon SRXs may be driven by the same input signal command. Is there any do way to do a similar thing using any SRX CAN closed-loop mode (via some kind of legal FIRST master/slave configuration)?
Unread 13-11-2015, 17:14
ozrien's Avatar
Omar Zrien
AKA: Omar
A "slave" CAN Talon SRX can be told to follow the output of ANY other CAN Talon SRX, even Talons that are closed-looping.
Please read section 9. Follower Mode in the Talon SRX Software reference Manual.
http://www.ctr-electronics.com/talon...ical_resources
Unread 13-11-2015, 19:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
While not germane to OP, it says there in section 21.15 that the Reverse Closed-Loop Output option is not available in C++. If you need it while using C++, you can just wire the motor backwards (e.g. red to green on the master and red to white on the slave). If you need to reverse it dynamically, you'll need Java or LV, or an updated version of C++. Note that "wiring one of the motors backwards" can also be used with a single motor controller if using Window/Wiper/Door, AM PG, Bosch, or Snow-Blower motors (according to the 2015 control rules R42, second row of table).
Unread 13-11-2015, 22:05
ozrien's Avatar
Omar Zrien
AKA: Omar
C++ users can absolutely reverse the output of a slave Talon so that is opposite in direction in respect to the master Talon it is following. Section 21.15 describes how to do this.
Unread 14-11-2015, 07:28
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The document on-line must be out of date. It begins with:
Originally Posted by 217-8080, top of page 84
21.15. C++: There is no method to reverse the output of a slave Talon SRX.
Edit: Not being a C++ programmer, I skipped on to the Java section. Looking at it now, I see that it is misleading rather than out of date.
