Go to Post This special is supposed to promote science, not convert the world to gracious professionalism (though that wouldn't be such a bad idea). - Karibou [more]
Unread 05-11-2015, 21:31
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Re: Preferred Programming Language
I'm just going to bump in for a little bit (again)
A lot of the responses on this thread are claiming that Java and C++ are very similar languages. I can't say I necessarily agree.
Although, yes, Java and C++ share some syntactical similarities, the way the languages work can be completely different. If you learn Java, you shouldn't try to program in C++ 'The Java Way', because that leads to issues and inefficiencies. Take pointers for example. In C++, your life revolves around them. In Java, your life also revolves around them. But the key difference is that in C++ you have to handle it on your own, while in Java just about every little bit of data you deal with is a pointer. This leads to issues if you go in with the mindset "these two languages are pretty much the same", because they're not.
If you want to find a language to use on your Robot, look at the pros and cons behind each, and decide what YOU want to learn and use, there's no wrong answer. But please, don't leave it up to "Learn C++ if you have the time, otherwise fall back to Java", because they're not the same language, they just happen to share a fairly common Syntax. Each language has its own advantages and disadvantages, and it's not as easy as "C++ is more hardcore", because I can promise you that although Java presents a friendly face, there's a lot of more you can do with it if you're willing to put in the time.
</rant>
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
