Go to Post I tried to convince my team to use the force but no one would listen. - ngreen [more]
  #44   Spotlight this post!
Unread 06-11-2015, 00:03
Jared's Avatar
Jared Jared is offline
Re: New Products for 2016: Speculation, Wants
Originally Posted by Cory View Post
We're not in the real world. This discussion is clearly about FRC and there really can be no debate that for FRC hex is a superior product.
I'd take hex over round 99 out of 100 times for transmitting torque, but I don't agree with a blanket statement that says hex is always the way to go, especially considering budget. It's undeniably cheaper to drive a McMaster Carr Sure-Grip wheel with a round shaft than a hex shaft.
Putting a hex in a 1.25" hardened steel worm is impossible for most teams that don't have access to a wire edm. Using a keyed shaft would be a better solution, especially if there isn't room in the worm for a 3/8" hex.
If you have a set of two driven rollers or wheels with a pair of bearings in between, you're forced to use a hex bearing here. The inner race of the hex bearing is much weaker than the inner race of the round bearing and has a sloppy fit. I'm pretty sure 254 solved this problem in the past on their outer wheels by using 1/2" keyed shaft...
