Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 01-11-2015, 23:07
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
[FTC]: Scoring Program Can't Schedule More Than 5 Matches per Team
The Scoring system has a built in limitation on the number of Matches that can be generated. From the manual:
"For the following Event types, Limitations have been set in the Scoring System to a maximum of 5 Matches. In addition, the cycle times (time between Matches) will automatically be no less than 7 minutes:
 League/Meet 
League Championship 
Qualifier 
Championship
Anyone know why? We can put 6 to 8 matches into our events easy and think it gives teams better results.
Thank you,
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
Unread 02-11-2015, 01:13
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: [FTC]: Scoring Program Can't Schedule More Than 5 Matches per Team
I haven't seen it offically anywhere, but I heard FIRST wanted to promote parity between events in different regions, hence the limitations. Here in MN, I believe the plan is to run 3+ practice matches before the official matches for teams.
Personally, I'm a fan of letting regions decide how many matches teams get over a certain minimum, but then, I also am a fan of actually giving teams feedback and we know how FIRST feels about that.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 03-11-2015, 23:15
AKA: Dan Glenn
Our region wants to standardize on 6 matches per team. The program can do it in "Scrimmage."
Does anyone know what changes if set the event to "Scrimmage?"
Are there any limitations in the program by using it this way?
Thank you,
Dan Glenn
Unread 04-11-2015, 02:06
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Originally Posted by cadandcookies View Post
I haven't seen it officially anywhere, but I heard FIRST wanted to promote parity between events in different regions, hence the limitations. Here in MN, I believe the plan is to run 3+ practice matches before the official matches for teams.
We're planning on running 2 practice matches and 5 qualification matches. Last year we averaged 7 qual matches a tournament while ending early. We'd like to at least do that this year.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 04-11-2015, 06:38
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
You could always run the amazing VEX Tournament Manager software. Everything is a user parameter you can set. I've run 32 team events with 4 fields and have gotten 10 plays per team in before 2PM (with a lunch break).
We do pre-warn teams about quick turn times and they need to manage their battery collection. We also have spares and extra chargers on site.
High cost of the robot, high cost of the entry for the event, transportation, food and only getting 5 plays seems like pretty bad value proposition.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 04-11-2015, 07:44
Allison K's Avatar
Allison K Allison K is offline
AKA: Allison Kneisler
FRC #3538 (Avondale RoboJackets)
Allison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond repute
What effect will a low match count have on the integrity of the rankings? Are there any statisticians in the crowd that can run quantitative data showing the relationship between number of seeding matches and accuracy of rankings?
Five matches seems a bit on the low side for accurate ranking. Though running extra practice matches is better than nothing I suppose.
If the issue is event consistency vs. event quality my opinion would be that inconsistent numbers of matches between events is the lesser evil compared to artificiality limiting all events.
Allison
Edit: I recall within the past year or two a post in an FRC thread showing the difference in noise in the rankings at 6 vs. 8 vs. 10 vs. 12 matches. It may have been one of the district vs. regional discussions? Anyway, tried to search but it's lost to me at the moment.
FRC3538 : RoboJackets : 2014-??? : Head Coach & Drive Coach
FRC226 : Hammerheads : 2003-2013 : Strategist
Unread 05-11-2015, 18:47
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
VEX seems like a bad value proposition to me. I'd much rather my students learn about design and the manufacturing of your design than "let's buy a specific set of parts and be limited by that". My students build a completely customized robot using a combination of 3D printed, CNC'd and manually milled parts after being designed from the ground-up in CAD. VEX is cool but students in more customizable programs learn a lot more and in turn become more inspired.
Unread 05-11-2015, 21:26
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
 League/Meet 
Qualifier 
Championship
Thank you,
This definitely sounds like a great question for the Q&A forum. I know from my experiences at some events, they have started doing judging before the qualifiers start to avoid having one run late and the other suffer scheduling wise, similar to at many FLL qualifying tournaments.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 05-11-2015, 23:12
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
"... bad value proposition"
Nah.
Certainly not without an agreed enumeration of expenses and results that can be assessed to determine both value, and barriers to entry.
The skills, tools and techniques you named can all be taught, used, and improved in VRC (and any of almost all other STEM programs that build things).
"... students in more customizable programs learn a lot more"
Nah
Students in all programs can learn what they are taught. If a student I am helping doesn't learn something they want to learn, I blame myself, not the program that happened to bring us together.
"... and in turn become more inspired."
A) Nah
B) We determine this how?
Do we weigh the students at the beginning and end of a season, to determine how much inspiration they absorbed? Do we measure their lung capacity, because "inspiration" can refer to breathing? Do we normalize the results by the number of students reached, or by the dollars the students can afford to invest in the program/team/robot costs?
This is a sore subject for me. FTC, VRC, FRC, and ... are all tools that all need to be used well. It's a poor craftsman who blames his tools.
Lets go back to the original topic.
Blake
Unread 06-11-2015, 06:19
Didn't say switch to VEX said, run the Tournament Software, it runs lots and lots of matches.
The second sentence applies to any robot program. Roboteers work hard on the robot, there are costs it seems a shame to only get 5 matches. Depending on the number of teams, 5 matches does not give a good base for rankings.
I'm a fan of all robot programs, just wished there were more roboteers in them.
Unread 06-11-2015, 12:55
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
I have posted a question asking for some reasoning to the FTC Scorekeepers forum, and will keep you all posted if I hear anything back and am allowed to share.
--Jacob
Illinois FTC FTA
Unread 09-11-2015, 22:23
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Crazy, we only have 12 teams at an event so only ~2 hours of matches??? a little ridiculous.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 17-11-2015, 12:28
AKA: Dan Glenn
Just checked the 11/1 update and the 5 match limitation still remains.
Anyone know where on the public FIRST forums we can discuss the Scoring system and other Tournament related questions?
Maths222 - Why would anything about the scoring system be private conversation? Without the Field Control System, Scorekeeping will be the central position of the event. We need to understand as much about it as we can.
FTC has been showing wonderful increasing transparency by posting all the volunteer documentation for the last couple of years. Just a few of these areas remain a mystery. I hope they continue to open up the transparency and let everyone in on the shared knowledge of these hidden forums.
Dan Glenn
Unread 18-11-2015, 20:05
Git 'em!
We learned here that if you choose your event type as super regional you can run as many matches as you like, no ill effects on rankings or scoring.
Robot in 3 Days
Unread 18-11-2015, 22:03
FTC FTA
Please don't do that for an official competition. FIRST would not be happy to find out about that.
--Jacob
Illinois FTC FTA
