Go to Post Anything worth analyzing is worth over-analyzing. And anything worth over-analyzing is worth hyper-analyzing. Ready, go! - Michael Hill [more]
Unread 05-11-2015, 22:28
the_42nd_parado's Avatar
the_42nd_parado the_42nd_parado is offline
Team Captain, who knows very little
AKA: Daniel
FRC #3240 (Team Orion)
the_42nd_parado is an unknown quantity at this point
Battery: Where did we go wrong?
Hello everybody,
I am sorry for my ignorance on what happened. One of our lead acid batteries is scaring us, no one on our team has any idea what happened. All we know is that in the morning there was something definitely wrong. The sides of the battery are bulged, as though there was a reaction that created pressure. Yet oddly it seems to only be affecting one side. It seems that the top (the black part) is separated from the battery. Also when we entered it smelled as though there was a gas leak in our shop. Though this may be a separate event. If anyone has any ideas on what happened I would love to know, and possibly save our remaining two batteries.
ID:	19401Click image for larger version
ID:	19403Click image for larger version
Thanks,
The_42nd_Paradox
Unread 05-11-2015, 22:31
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Battery: Where did we go wrong?
I can't comment on what caused it but I am surprised the vents didn't pop up. We had a bad battery and the vents popped up and stunk up the whole hallway.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 05-11-2015, 22:50
mrmummert's Avatar
mrmummert mrmummert is offline
AKA: hank
FRC #1610 (bot)
mrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to behold
Send a message via Yahoo to mrmummert
We had two of ours do that recently too. I've read that it can be caused by being over charged but the charger we use is supposed to prevent that.
I'm wondering if it might have something to do with the batteries having been used laying on their side while in the robot. None of our 2015 batteries did it, but a 2014 one did and i think a 2012 battery might have been the other one.
winner vcu 2006,winner vcu 2013,2014,2015
Unread 05-11-2015, 22:59
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
That battery needs to be sent to be recycled. It is bad. Either a cell shorted out or it was charged with the wrong high rate charger.
Make sure the max charge rate is 6 amps, 2 is better. Microprocessor controlled 3 or 4 stage charging is best and make sure it is compatible with AGM / GEL batteries. Liquid cells like in auto batteries have a different charge profile.
We have had maybe 3 or 4 failures in 12 years ? We keep 14 batteries in service, so altogether we have not had a real problem.
Ed Barker
Unread 05-11-2015, 23:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you want help figuring out what went wrong, you might need to provide some clues. Like, what was done to the battery? was it just sitting in a nice dark cool room all by itself? was it connected to a charger? was it exposed to temperature extremes? was it shorted out? How old is it?
As mentioned, it doesn't really matter for this battery, but if you have others that might be mistreated some how, it would be helpful for you to tell us all that you know about what was done to the suspect battery.
Unread 06-11-2015, 07:38
AKA: Daniel
The charger we use is also designed to prevent overcharging as well. As for the batteries being laid on there sides, I do not not think so, the rest of our batteries have laid on there sides and have not done anything like this.
Ok one of our mentors is taking the battery to a hazardous waste recycling center. Also when I get back into our shop I'll try to find out weather the charger is 6 or 2 amp, also if it is Microprocessor controlled. However I am fairly certain it is 3 amp.
I know we were charging the battery in preparation for a demo tomorrow. Though our charger is designed (as stated before) to prevent overcharging. As for possible temperature shifts there is a high possibility as our shop is not air conditioned. Shorted out I do not think so, the connectors were fine. If there was a short it would be in our charger. Also as stated before the battery was given to us in 2010 for frc. I guess it may have run its life.
Well thanks everyone for your replies.
The_42nd_Paradox
Unread 06-11-2015, 08:05
Other ways of mistreating a battery include:
  • Grabbing a battery by it's wires instead of the built-in grips (the battery terminals are not mechanical supports and pressure on them will crack the internal plates)
  • Dropping a battery onto a hard surface, also rupturing or cracking internals (can inspect for dented corners)
  • Very deep discharging maybe >80%
  • Sensitive to over-charging (a bad battery can give confusing feedback to a good charger)
  • Overheating (hot storage, hot surface)
  • Not maintained in a charged state (leaving them to slowly discharge all summer will damage them)
But just age will eventually lead to deterioration and then overcharging even with a smart charger can occur.
Unread 06-11-2015, 08:40
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Listen to this man! He knows his batteries. A lot of our battery process has been taken from 1311. Including our cart.
Unread 06-11-2015, 08:44
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
I often see people using chargers that make lots of claims about overcharging this and that but I have lots of experience with batteries (built electric vehicles and computer room battery backups). I rarely trust a battery charger I either haven't got extensive historical data or at least a complete schematic and source code for.
I have lots of wet maintenance free batteries around. I check them for temperature and any signs of leakage and if possible collect any data I can for their behavior often. The real important thing is to not have these things spraying acid everywhere because that might just be the start of your troubles.
All in all after doing FIRST on and off for 20 years I think the battery selection for FIRST is adequately safe. Though it wouldn't surprise me to see an occasional issue here and there.
As others have pointed out, once you recognize you have a battery in a bad state it is important you dispose of it not leave it laying about. You don't want someone happening upon it later and compounding the safety issue.
Unread 06-11-2015, 09:05
Daniel,
This is common failure for these batteries. In almost all cases, an inspection of the bottom of the battery will show some damage. It is likely that the battery was dropped at some point. The construction of these batteries reduce the gap between plates (compared to previous gel cell types) and that gap is filled with a wet glass mat. When dropped, the plates may move to close the gap. Eventually when charged, the charge voltage exceeds the breakdown provided by the gap and causes a short internal to that cell. When that occurs, temperature skyrockets in that cell, demonstrated by the swelling of a small section of the side of the battery. Temps rise so fast that the small gas valve cannot release all of the pressure. A combination of high temperature and excessive gas pressure causes the case to warp outward. When the battery cools, place it in two plastic bags to prevent the leakage from damaging other parts and hands and recycle as advised above.
Remember that each cell is rated at 18 AH and each cell is capable of providing 500+ amps when fully charged. That is easily 1000 watts per cell until the the energy is given up as heat and the cell discharges. The damage due to dropping will not always show up immediately but I have seen a few brand new batteries that have exhibited these issues.
These batteries can be used in any orientation and can be charged in any orientation. I personally only charge when battery is standing up to give the pressure valves a better chance of doing their job.
If you could supply a picture of the bottom of the battery, we might be able to see the cause.
Unread 06-11-2015, 10:07
MrForbes's Avatar
AKA: Jim
That is as long as I would ever expect a battery like this to last.
Unread 06-11-2015, 10:35
AKA: Daniel
Daniel,
I just got a look at the battery, sorry for the lack of photos my phones camera is from ~7 years a go, flip phone. Regardless I could see no major damage to the bottom, no cracks or obvious dents. However the bottom did seem scraped up, but that may just be due to normal wear and tear.
Well regardless from this point forward we will only charge batteries under supervision. Hopefully this will reduce our problem.
Eidt:
Just found the battery charger specs after posting this. Here is the charger we are using:
http://www.andymark.com/Battery-Char...-p/am-2026.htm
Last edited by the_42nd_parado : 06-11-2015 at 10:37. Reason: Found more information
Unread 06-11-2015, 11:03
ebarker's Avatar
AKA: Ed Barker
Regarding chargers, we have several.
We have this charger from Deltran
http://www.batterytender.com/Charger...er-12V-2A.html
Also if you get a Deltran, search online. The street price is about 500 bucks, much less than list price.
Using this Deltran charger has given us stunningly good results in maintaining batteries in a very good fashion and maintaining a long life. The 2 AMP charge rate is ideal for the types of 18AH batteries we use. Frankly I think it is the best and works great for competition if you have enough batteries to manage the longer charge time.
Our other battery support system is essentially identical to the one here except we use a different battery charger. This is the charger that we use
It has a 5 AMP peak charge rate. I don't have scientific evidence but my feeling is that the 2 AMP Deltran is much better at helping the batteries live a long life. The reason we have this system ( 14 chargers @ 5 AMPS ) is to support 8+ hour long multi-robot public demos. It is hard on robots and batteries.
A picture of the system is here.
It has been updated to have a mid-rail plug mounting system like Team 900's.
As for the Schumacher chargers - I just don't like them, at all.
One more time - we REALLY like how the 2 AMP Deltran takes care of batteries.
Ed Barker
Unread 06-11-2015, 11:15
AdamHeard's Avatar
Lead Mentor
What about them?
Unread 06-11-2015, 11:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What about them?
I don't like that they have buttons, selectable voltage, and selectable charge rate. The led bar graph is nice though.
