Go to Post Get your team together. Get your priorities straight. Get busy having fun. See you on the field. - EricH [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-11-2015, 16:00
silver505's Avatar
silver505 silver505 is offline
Dragon Robotics 2375
AKA: Marlen (Thing 2)
FRC #2375 (Dragon Robotics)
Team Role: Photography
silver505 can only hope to improve
HELP WITH VEX
Our school doesn't do Vex, but recently I have had an internship with a school that has. They have asked me for some help. So they have a 10:1 gear ratio, how can they increase the velocity with limited resources? I think that is the biggest their ratio can go.
Unread 06-11-2015, 16:08
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Re: HELP WITH VEX
If you mean VEX EDR then you will find better help on the vexforums.
You will also get more help if you include more information in your post, such as what you are planning, how the gearing is set up, and why the speed needs to be increased. Currently your post is extremely vague and unlikely to garner much useful information.
Unread 06-11-2015, 16:11
Bob Steele's Avatar
AKA: Bob Steele
Re: HELP WITH VEX
Have you thought of doing 2 or more reductions to get the higher speed?
You probably want to figure out a gear box using available VEX gears to bring the speed up to whatever you need. Just remember you will be trading speed for torque and the gear box may have more friction than you want so you may not be able to get really high speeds after you apply a load to this system.
Good luck
Unread 06-11-2015, 16:12
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: HELP WITH VEX
They can stack the gears.
Lets assume they are driving a 84 tooth gear with a motor, that gear is driving a 12 tooth gear.
If they put a 12 tooth gear on the same shaft as the 84 tooth gear and the drive the new 12 gear with an 84 tooth gear they will get more speed out of it.
Remember, that speed is the inverse of torque, so has the speed goes up, the torque goes down. So while the last 12 tooth gear is spinning pretty fast, it won't have a lot of power.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 06-11-2015, 19:16
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: HELP WITH VEX
Is this ratio part of the drive train, or part of a"shooter", or part of something else?
Unread 06-11-2015, 19:44
Chris is me's Avatar
AKA: Pinecone
Re: HELP WITH VEX
There isn't actually a way to get a 10:1 ratio in Vex with just gears. You can only get combinations of 1, 3, 5, and 7 (12, 36, 60, 84).
I've heard as a rule of thumb, a good ratio for 4" wheels on both sides of the ball with 2 motors per wheel is 49:3, which can be achieved with a 12:84 and a 36:84 gearset.
Unread 06-11-2015, 21:10
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: HELP WITH VEX
Two stage 10:1 gearbox with Vex gears is no issue....
With a 12 tooth CIM gear.
48 and 20 on a lay shaft. CIM drives the 48, 20 drives the 50 on the output shaft.
(48/12)(50/20)=10:1
Replacing the 48 gear with a 44, 42, 40, or 36 would reduce the gear ratio and provide faster velocity and lower torque.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 06-11-2015, 21:24
Re: HELP WITH VEX
Just as a point of clarity, VEX could commonly refer to any one of the following:
-VEX Robotics (division of IFI)
-VEX Robotics Competition (VRC) (robot competition using VEX EDR and IQ robots)
-VEX IQ (robot parts series designed for the same market as LEGO Mindstorms/FLL)
-VEX EDR (robot parts series designed for the same target age as FTC--the original FTC kit...)
-VEXPro (robot parts series designed for FRC)
From the context, you're referring to VEXPro, while the OP is referring to one of the other items on the list, likely VRC or VEX EDR (or both, given that VEX EDR is used in VRC). CIMs don't work very well with the EDR line.
Unread 07-11-2015, 00:08
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: HELP WITH VEX
Minor correction. The VEX Robotics Competition specifically refers to a robotics competition for middle and high school students using VEX EDR parts. The VEX IQ Challenge is a robotics competition for elementary and middle school students using VEX IQ parts.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
