Go to Post The point is that while having the abiltity to find information in a variety of reference sources is a useful skill, it does not replace a good, complete, fundamental knowledge of your subject material. - dlavery [more]
  #31   Spotlight this post!
Unread 27-02-2003, 20:41
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
Re: Hmmm
Originally posted by Clark Gilbert
There is another way...
Force it down, and then pull it up.
I've done some research on the internet and there are a ton of suction cups out there, (even rectange shaped). It should be really interesting what teams use this year and how they use them.
Our robot can do that, we push the cups down and then bulld them down to have all four wheels contact to create more resistance. The pneumatic is so strong that is pulls the HDPE towards the robot!! Maybe thats because our mock ups bad, but that could be a problem with people who use 2 huge vaccum cups.
I think suction cups will prove to be a determing factor this year.
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
  #32   Spotlight this post!
Unread 27-02-2003, 20:51
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
But back to the point I was trying to make, the amount of force that a bot has going 12 FPS weighing 130 pounds far outweighs what ive seen in the suction cups. I also think that even if a robot that was rammed at full speed into a robot secured with suction cups *IF* they even to withstand that kinda punch, There seals would for the most chances break.
Hows my searching? Call 1-800-Green-Dots
  #33   Spotlight this post!
Unread 27-02-2003, 23:20
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Suction cups will work good for the first few practice matches and maybe some into the qualifying but by the time finals hit that HDPE will look like a scratching post covered in dust, dirst, and oil. Everyones pro-suction point is saying they can withstand exert a huge force on a glass-smooth surface, chances are the HDPE will be more like a rough concrete. If teams still want to go with suction cups it seems logical to go with 20 small ones instead of 1 or 2 large ones to minimize the risk of trying to lock onto an area with a scratch.
Do you want to take the chance that during finals your bot trys to lock onto the joint between the 2 pieces of HDPE and another bot knowcks you off like you weren't even there?
Also Ramp-doms have to stay for nearly the entire 2 minuts and even if the scratches only allow a slow leak chances are the ramp-dom would have to re-attach every so often.
The best option is to put some _ _ _ _ _ _ _ _ breaks on the bottom of your bot and get a COF of about 2.0 or if your budget allows and you can find it get some _ _ _ _ _ which will give you a COF of about 3.5.
Friction brakes are more reliable and lighter.
  #34   Spotlight this post!
Unread 27-02-2003, 23:49
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Just remember- you have to be on the top of the ramp to use your suction cup...
if you aren't first.. tough luck..
  #35   Spotlight this post!
Unread 28-02-2003, 14:37
D.J. Fluck
Posts: n/a
From official FIRST forums:
FIRST expects the HDPE surface to become marked and soiled. The platform will be cleaned occasionally. The frequency of cleaning will depend on the amount of soiling and the time schedule of the matches. There is no guarantee that the platform surface will be clean for every match.
<Edit>
Also found this
We will try our best to maintain the condition of the HDPE. There is no schedule for replacement. There is no means for repair. We can keep it somewhat clean. Expect wear and tear. Do not expect a perfect surface for suction cup attachment. There is a seam in the HDPE at mid-platform. Because of the time required to change the HDPE, its condition will be evaluated at mid-day breaks. Spare HDPE sheets will be on site at each competition. The HDPE can be flipped to gain a new surface. We will not be able to determine the the amount of wear and tear that the HDPE will receive until we experience its use in the first week of competition. Do not expect perfect conditions for each match.
  #36   Spotlight this post!
Unread 03-03-2003, 21:25
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
Suction Cups slide - maybe you haven't been informed, but there are some suction cups out there that are completly immovable, as far as you know the KATS have one on each arm
look here....Gope: 10:02pm
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
  #37   Spotlight this post!
Unread 03-03-2003, 21:40
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
im liking the idea of suction cups even more at every moment
45's suction cups are sweet. meant for load paralell to the attaching surface, they should hold very well.
  #38   Spotlight this post!
Unread 04-03-2003, 03:29
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
wouldn't it really be from what kind of suction cup you used? If the suction cups had a very large edge to them, spare material they might hold. Think like a dinner plate, the indented area being the suction cup. There is a wide lip around the whole thing, now if that was wide enough, say maybe 3 inches of just extra material where it met the floor it could probably compensate for short 2 inch marks because the extra material would completely cover all the short ones that got under it at all and those that started midway wouldn't have access to the vacuum inside. Our team did not have an opportunity to make an entire ramp top to see how long the usual marks are or how deep they are but I'm guessing they might be deep but short meaning that might be a solution. Dust might be a problem but I don't think many robots will be dumping chain grease everywhere for the simple reason that they would work hard to fix that for the safety of their own electronics panel if nothing else. Any team that didn't wouldn't be playing many matches in which they got on the ramp anyway.
I completely admit this is all in the wonderful world of logic which often has nothing to do with the real world, please tell me how far from reality any of it has gone in your experience.
  #39   Spotlight this post!
Unread 22-03-2003, 22:36
Gusman1188 Gusman1188 is offline
FRC #0870
Rookie Year: 1930
Gusman1188 will become famous soon enoughGusman1188 will become famous soon enough
that is a pic. of my teams suction cups and there are two 300 pound suction cups, totaling a 600 lb vacuum. Dont believe me? No robot in two regionals could move us and robots actually bounced off our bot, in fact there so effective that in order to get the robot up at the end, we have to depressurize our pnuematics.
Team R.I.C.E. 870
2006 SBPLI Regional Winner
2006 SBPLI Imagery Award
2005 SBPLI Regional Winner
2004 SBPLI Xerox Creativity
2003 SBPLI Regional Winner
2003 CT J&J Sportsmanship
2003 SBPLI KPC&B Entrepenuership
2002 SBPLI Rookie All-Star
  #40   Spotlight this post!
Unread 22-03-2003, 22:56
Lisa Rodriguez Lisa Rodriguez is offline
Biology Grad Student.....
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
Lisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant future
Send a message via AIM to Lisa Rodriguez Send a message via MSN to Lisa Rodriguez
Only FIRST sparks so much discussion about suction cups
This thing still works?
it's never over unless you let it be over
  #41   Spotlight this post!
Unread 22-03-2003, 22:58
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
If anyone cares, I must point out, that suction cups is what won the regional at SBPLI, 2 out of the 3 teams used them, ourselves and one of our alliance partners. We would simply go to the top of the ramp, suction down, not be moved, and theres 50 points right there, kinda hard to come back with 1 bot and no multipliers
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
  #42   Spotlight this post!
Unread 22-03-2003, 23:35
philipprogramer philipprogramer is offline
#0762 (Patriots)
Team Role: Operator
philipprogramer is an unknown quantity at this point
Easy Way to win against suction cups
I might point out that the only way the suction cups will work is like OneAngryDaisy said you have to make it to the top of the ramp to suction down. In the Florida Regionals we were up against a team with good suction cups but we wouldn't let them get up to the ramp.
Team 762
1st Seed UCF 2003
7th Seed UCF 2004
Quater-finalists (thanks 312 and 59)
GM Industrial Design Judge's Award UCF 2004
ANYTHING is Possible
  #43   Spotlight this post!
Unread 29-03-2003, 22:47
Pin Man Pin Man is offline
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJ²)
Pin Man has a spectacular aura aboutPin Man has a spectacular aura aboutPin Man has a spectacular aura about
Send a message via AIM to Pin Man
Awesome... I can't wait to see them in action...
AIM SN: ThursdayCambria
Attending Bridgewater State College
Shirt collection- 25, 47, 69, 140, 173, 191, 213, 303, 365, 461, 836, (2)862, 885, 888, 1027, (2)1073, 1156.
Shirts in the works-
Shirt Wish List- 45, 48, 61, 67, 84, 86, 95, 103, 111, 126, 175, 190, 233, 236, 716, 870, 871, 1114, and any other team basically
  #44   Spotlight this post!
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJ²)
  #45   Spotlight this post!
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJ²)
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
pic: Team 870 Wiring Nightmare CD47-Bot Robot Showcase 15 02-03-2003 21:46
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
