Go to Post I would ask for Florida to take a vote on best team, but my fear of "Hanging Chad" in close decisions has not fully subsided. - IKE [more]
Unread 06-11-2015, 11:47
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Battery: Where did we go wrong?
Originally Posted by sanddrag View Post
I don't like that they have buttons, selectable voltage, and selectable charge rate. The led bar graph is nice though.
If they work for you and you like them, ignore my comments, but in my experience they seem to 'get lost' when changing batteries and we would just unplug the charger from the wall and re-plug it in. But it may be we are just too impatient.
Whereas the Deltran seems to have a loving attitude to our batteries much more so: https://www.youtube.com/watch?v=2JlVqfC8-UI
Ed Barker
Unread 06-11-2015, 13:13
DonShaw DonShaw is offline
FRC #1261
DonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of light
Exclamation Re: Battery: Where did we go wrong?
First off a flooded lead acid battery is not designed to be used or charged in any other position other than upright. They should never be charged on the side as the acid may leak out and the plates may fall out of their brackets and short out.
There are two other types of batteries AGM (absorbed glass mat) may be used horizontal or at an angle but still it is recommended to be charged upright. Gel batteries are better than flooded since the plates are suspended in a jello like liquid helping hold the plates apart and perform better since the gel acts as a dampening agent.
We have transitioned over to AGM batteries for the safety of being sealed and being designed to be used at other orientations. They are also a bit more environmentally friendly since they have nominal lead in them.
Each battery has its pros and cons.
You may want to read this link on basic batteries.
http://www.batterystuff.com/kb/artic...ry-basics.html
Last edited by DonShaw : 06-11-2015 at 20:07. Reason: left out part of a word no should have been nominal
Unread 06-11-2015, 14:10
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Originally Posted by DonShaw View Post
We have transitioned over to AGM batteries for the safety of being sealed and being designed to be used at other orientations. They are also a bit more environmentally friendly since they have no lead in them.
I was under the impression that (according to 2015 rules) everyone had to use Sealed Lead-Acid batteries to power the robot.
Originally Posted by 2015 Game Manual
R20: The only legal source of electrical energy for the ROBOT during the competition, the ROBOT battery, must be a non-spillable sealed lead acid (SLA) battery with the following specifications:
A. Nominal voltage: 12V
B. Nominal capacity at 20 hour discharge rate: minimum 17Ah, maximum 18.2Ah
C. Shape: Rectangular
D. Nominal Dimensions:7.1 in x 3in. x 6.6 in (+/- .1 in. for each dimension)
E. Nominal weight: 11lbs to 14.5 lbs
F. Terminals: Nut and bolt style
Emphasis mine. Maybe I'm misinterpreting?
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 06-11-2015, 15:26
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Perhaps during non-competition use?
Unread 06-11-2015, 15:46
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
AGM is a type of sealed lead-acid battery. I don't know why he says they have no lead, because they do.
Unread 06-11-2015, 16:10
I am Dave! Yognaut
AKA: Brian Bray
Does any AGM battery exist that meets R20?
Originally Posted by 4.8-R20 - 2015
R20
Blue Box
EXAMPLES of batteries which meet this criteria include:
Enersys (P/N: NP18-12, NP18-12B, NP18-12BFR)
MK Battery (P/N: ES17-12)
Battery Mart (P/N: SLA-12V18)
Sigma (P/N: SP12-18)
Universal Battery (P/N: UB12180)
Power Patrol (P/N: SLA1116)
Werker Battery (P/N: WKA12-18NB)
Power Sonic (P/N: PS-12180NB)
Yuasa (P/N: NP18-12B)
Panasonic (P/N: LC-RD-1217)
Interstate Batteries (P/N: BSL1116)
Teams should be aware that they may be asked to provide documentation of the specifications of any battery not listed above.
Batteries should be charged in accordance with manufacturer’s specification. The battery charger output should not exceed 6 amps and they must have the corresponding Anderson connector installed. (Please see the FIRST Safety Manual for additional information.)
/Blue Box
Unread 06-11-2015, 19:25
philso philso is offline
FRC #2587
Originally Posted by the_42nd_parado View Post
the battery was given to us in 2010 for frc. I guess it may have run its life.
Yes. The UPS' manufactured where I work use tons (literally) of Enersys batteries from the same family as the FRC legal models. We recommend that our customers replace them after 3 years. The charge and discharge rates our UPS' subject the batteries to are not as "abusive" (especially discharge) as in an FRC robot so I would expect less than 3 years of life when used in an FRC robot.
Unread 06-11-2015, 20:42
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Don didn't say no lead. He said nominal lead. Nominal lead is the lead normal people use. . The recycle stream for lead is very good. You return your battery to a recyler, as you should, it will get ground up and made into a new battery. Near zero impact on the environment.
Yes there are AGM batteries that are FRC legal
Unread 07-11-2015, 09:57
Ari423's Avatar
FRC #5987 (Galaxia)
At first he said "no" then he changed it to "nominal". If I would have realized it was a typo I never would have said anything.
2013: Programmer
Unread 07-11-2015, 11:33
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
I missed that. Nominal is a funny word anyway. It can mean approximately normal like all readings are nominal or it could mean insignificant. One the oddities of the English language trying be all things to all people.
In any case FRC legal AGM batteries are lead acid batteries and have sufficient lead in them for the reaction to work.
Unread 09-11-2015, 07:36
AGM batteries actually may have slightly more lead than previous gel cell types. The glass mat allows for closer plate spacing which may allow manufacturers to add one more plate in the same space as previous designs. This gives a little higher energy density and/or available peak current. The reason FRC went to AGM batteries (namely the MK series) came from a donation by MK to supply batteries to every team that year. The AGM design also keeps maximum contact between electrolyte and full plate during the battery's lifetime. This AGM series also lightly reduced the weight of batteries. Previous gel types could be up to 14 lbs when new. As the electrolyte evaporated, the weight went down but so did the available current and energy density.
Batteries used in safety light service are designed to be on trickle charge 24/7 so they have a tendency to outgas and remain at higher temperatures. Many jurisdictions also require safety lighting to provide light for a specific minimum time period. Older batteries in this service will meet that spec. Many building maintenance managers will replace all batteries every three years or sooner, depending on environment.
Unread 22-02-2016, 20:36
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Reviving this just to note we had a failure today as well. We were using the Andymark tripple charger for the battery. Open Circuit voltage is 13.52V. I have checked the charger and it is consistently float charging at 13.35-13.40V per battery.
Unread 22-02-2016, 21:47
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Hello everybody,
I am sorry for my ignorance on what happened. One of our lead acid batteries is scaring us, no one on our team has any idea what happened. All we know is that in the morning there was something definitely wrong. The sides of the battery are bulged, as though there was a reaction that created pressure. Yet oddly it seems to only be affecting one side. It seems that the top (the black part) is separated from the battery. Also when we entered it smelled as though there was a gas leak in our shop. Though this may be a separate event. If anyone has any ideas on what happened I would love to know, and possibly save our remaining two batteries.
Attachment 19401Attachment 19402
Attachment 19403Attachment 19404
Thanks,
The_42nd_Paradox
Based on all your input my guess is that batt was last charged and not erect.
(i.e. on one of its sides)
It is perfectly OK to DISCHARGE the battery in any orientation.
Charging must always be upright to prevent gas accumulation pockets which could cause case bulging due to normal pathways being blocked. In an older battery this may be the more likely scenario. Gas generation is natural in charge mode and normally is re-absorbed. Gas is not normally generated when discharging. (reverse chemistry)
We successfully use FIRST batteries for 6-7 years (since 1999), tho as they get older just for test and evaluation. Our "charge" policy is to always have them on a charger as soon as practical after being used, and always while being stored.
Only exception is if the battery self heated in a particularly push push match - then wait until batt isn't noticeably warm to the touch (~ room temp) before charging.
Every team sould invest in a Battery Capacity tester and keep records (id ea batt ea yr 2016-1, 2016-2.. it can be done manually and produces instructive discharge curves - we use 50A as match average simulated load ~.25 ohm but must be rated a minimum of 500W (use fan) test will fully exhaust batt capacity in ~9 min.. I can send a sample of the data and plot if you send me a personal email if my jpg attachment did not post here 50A Load Discharge graph+data)
Unread 22-02-2016, 22:05
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
Do you have any recommendation for a battery capacity tester?
Unread 22-02-2016, 22:18
West Mountain Radio
http://www.westmountainradio.com/cba.php
