Go to Post Some of them look like phone numbers... LETS START CALLING THEM ALL! - akoscielski3 [more]
Unread 17-01-2002, 23:46
l1jmx's Avatar
l1jmx l1jmx is offline
#0840 (ART)
l1jmx is an unknown quantity at this point
Send a message via AIM to l1jmx
Drill Shaft Coupler questions
Okay, we just got out drill motor shaft couplers from SPI @ $25 a piece (UGGH!). Anyways, we're trying to figure out how to make the "spring pins" on these guys work. The catalog page says there's supposed to be a hole for a 1/16th of an inch spring pin and that the shaft coupler was supposed to come with 2 spring pins. In our bag, however, were 2 pins that seem to be made out of solid metal (nothing springy about them), and they are 1/8th of an inch thick. There is no way we're fitting this pin through this tiny hole. However, in spite of the apparant failure of small parts to send us the correct item, I'm sure we've got 1/16th of an inch pins sitting around somewhere. The bigger question is a matter of how one goes about putting this pin through the solid shaft coming out of the gear box. Does anyone have suggestions for drilling out the necessary hole?
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
