Go to Post Each team is different, your mileage may vary. What works for your team does NOT necessarily mean it will work for others. - Andrew Schreiber [more]
Unread 06-11-2015, 20:42
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Battery: Where did we go wrong?
Don didn't say no lead. He said nominal lead. Nominal lead is the lead normal people use. . The recycle stream for lead is very good. You return your battery to a recyler, as you should, it will get ground up and made into a new battery. Near zero impact on the environment.
Yes there are AGM batteries that are FRC legal
