Go to Post when you think you are here to compete against other teams, thats when bad things start happening... - KenWittlief [more]
  #31   Spotlight this post!
Unread 18-10-2015, 20:48
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Re: Dog Shifting Gearbox Feedback
To elaborate more, there is a strength advantage but not a stiffness advantage. So there are many applications where people might think their plate is too "weak" where changing alloy won't help at all, as what they really want is stiffness.
Wow, I didn't know this. I always thought that 6061-T6 is stiffer than 5052-H32 as it makes logical sense: 5052 bends and 6061 doesnt.
Originally Posted by Knufire View Post
Yeah, I found plenty of examples of bent 1/8" gearbox plates but we don't have access to a decent brake.
Modulus of elasticity for 6061-T6: 10000 ksi
And for 5052-H32: 10200 ksi
As Adam said, 5052 is actually stiffer than 6061-T6. You would also need a laser cutter to make the plates with 5052 as it cant effectively be machined with a mill.
  #32   Spotlight this post!
Unread 18-10-2015, 20:53
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Originally Posted by SerpentEagle View Post
As Adam said, 5052 is actually slightly stiffer than 6061-T6. You would also need a laser cutter to make the plates with 5052 as it cant effectively be machined with a mill.
I wouldn't say "can't." It doesn't machine as nicely as 6061, but it can certaintly be done effectively with care and the correct tools. We regulary perform secondary milling operations on 5052 bent parts with our mill.
Either way, unlightened, unbent plates as thin as .090 are definitely workable for gearboxes.
  #33   Spotlight this post!
Unread 18-10-2015, 21:13
AdamHeard's Avatar
Lead Mentor
I was making the point that they are essentially the same stiffness.
  #34   Spotlight this post!
Unread 18-10-2015, 21:29
Team Role: CAD
Rookie Year: 2015
As low as .090? Would bearings stay put with that thin of a material?
  #35   Spotlight this post!
Unread 18-10-2015, 21:33
Joe G.'s Avatar
AKA: Josepher
We use positive bearing retention on all of our laser cut gearboxes rather than relying on press fits.
  #36   Spotlight this post!
Unread 18-10-2015, 21:48
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Are you saying your relying on the geometry to keep your bearings in? Such as the shoulder of the shaft + the flange of the bearing?
R.C.
MadTown Robotics Team 1323
  #37   Spotlight this post!
Unread 18-10-2015, 22:20
Joe G.'s Avatar
AKA: Josepher
No, should have clarified. Retention is almost always through rivets+washers clamping down on the bearing flange. We'll occasionally do it through other parts of the system, but never something as likely to be seperated from the gearbox during maintenance as a shaft.
  #38   Spotlight this post!
Unread 08-11-2015, 23:04
electronicsdude's Avatar
electronicsdude electronicsdude is offline
AKA: Spencer
FRC #4918 (The Roboctopi)
electronicsdude will become famous soon enoughelectronicsdude will become famous soon enough
With 4 CIMs, according to my spreadsheet, I get around 2 fps less speed on high gear. I know that 6 CIM drivetrains don't have as much improvement as lets say a 2 CIM to 4CIM, but I assume that acceleration and pushing force is a big component to games with defense. Again, according to my calculations, a 4 CIM drivetrain would lose almost 300 inch-lbs of torque on low gear when compared to a 6 CIM with my setup.
On our robot two years ago, a ball shifting setup with two full-size CIM's to a 6 wheel drop center had tons of power, enough to spin four-inch taction wheels. I think the bottleneck is not the amount of motor power or gearbox torque after two CIM's but the traction and number of wheels contacting the ground.
Also think about how much power you consume every match. Its a lot faster to chage a 30% depleted battery than a 50 or 60% depleted battery. If you have the resources to charge enough batteries fast enough than you'd be fine. Just points to consider.
