Go to Post first robotics is a ten - Hiteak [more]
  #31   Spotlight this post!
Unread 09-11-2015, 01:27
Happy Birthday! Akash Rastogi Akash Rastogi is offline
Re: Tem 973 Pruhzents: SKYSTALKER-ER
Originally Posted by Jared Russell View Post
This is definitely the best FRC parody of an FRC parody I have seen.
How much deeper can we go?
  #32   Spotlight this post!
Unread 09-11-2015, 02:44
Aren Siekmeier's Avatar
on walkabout
Originally Posted by JackFisher View Post
realized video was shaky and cropped, so I fixed it and its all better now.
I thought that was on purpose...
  #33   Spotlight this post!
Unread 09-11-2015, 03:43
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
I almost fell out of my chair when I saw you painted it blue.
  #34   Spotlight this post!
Unread 09-11-2015, 08:47
Joining the 900 Meme Team
FRC #0079
They're rc car tires.
Any tricks on assembling? The ones we used last year on one of our intakes just took forever.
  #35   Spotlight this post!
Unread 09-11-2015, 09:01
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
The fact that that robot actually works better then anything my team has ever built is kinda sad.
  #36   Spotlight this post!
Unread 09-11-2015, 12:23
JackFisher's Avatar
JackFisher JackFisher is offline
JackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud ofJackFisher has much to be proud of
They do take awhile, but if you assemble then right the first time, they generally don't open up over use. Quality of hubs certainly affects this. We've only had issues with wheels when they weren't initially assembled correctly.
  #37   Spotlight this post!
Unread 09-11-2015, 12:28
AdamHeard's Avatar
Lead Mentor
If you've done it once or twice and have the right tool, it only takes 2-3 minutes and it will never slip. We ran crazy torque on them in 2011 and 2014 and only ones that were assembled with the bead clearly popping out ever slipped.
The tires are 1.9 and 2.2 Chisels from Proline, on Axial 1.9 and 2.2 8 Hole beadlock hubs. We directly hex broach the axial hubs (which yes, unfortunately means you have to buy new hubs each year for comp bot for an essentially COTS part).
  #38   Spotlight this post!
Unread 09-11-2015, 14:28
FRC #0079
The tires are Axial 1.9 and 2.2 Chisels from Proline, on Axial 1.9 and 2.2 8 Hole beadlock hubs. We directly hex broach the axial hubs (which yes, unfortunately means you have to buy new hubs each year for comp bot for an essentially COTS part).
Those look about like the hubs we used (Brando brought 'em in to try)
Guess it's just a practice thing, I remember it getting easier over time but it still seemed to be a pain. Better lighting might have helped.
  #39   Spotlight this post!
Unread 09-11-2015, 14:32
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Very nice! It looks (and performs?) frighteningly like a simplified 254 robot... Just shows how much good design can get you, even if 'build quality' isn't the finest.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
  #40   Spotlight this post!
Unread 09-11-2015, 14:43
Mitchell1714's Avatar
Mitchell1714 Mitchell1714 is offline
What's better than robotics?
AKA: Mitchell Schlidt
FRC #1714 (MORE Robotics)
Mitchell1714 will become famous soon enough
Its weird to think about how this video session started almost 3 years ago when 118 just wanted to print some copies.
2016-present: 1714(Alumni)
2011-2015: 1714(Student, FRC)
2013-2015: 1714(Student, VEX)
2006-2011: 1714(FLL)
  #41   Spotlight this post!
Unread 09-11-2015, 15:34
TravusCubington's Avatar
TravusCubington TravusCubington is offline
nasuh ENgineer n chief mentaur
FRC #0254 (Teh Chezy Pofs)
Rookie Year: 1974
TravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond reputeTravusCubington has a reputation beyond repute
  #42   Spotlight this post!
Unread 09-11-2015, 16:34
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
After looking at that robot a little more it occurred to me that there must be some complex math driving the angle of that curved back. I was woundering if someone might be able to outline that for me.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
  #43   Spotlight this post!
Unread 09-11-2015, 17:11
AdamHeard's Avatar
Lead Mentor
Intake portion is a 25" radius, then there is ~9" of straight vertical, then the shooter is 23" radius.
Not complicated at all
Could be laid out by hand easily w/ some straight edges, some string and a marker.
  #44   Spotlight this post!
Unread 09-11-2015, 17:13
Knufire Knufire is offline
CAD sketches are your best friend.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #45   Spotlight this post!
Unread 09-11-2015, 19:42
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
Can you post some documentation about the process of building this? I think this would shed some light on the prototyping process of the best of teams.
