Go to Post Sometimes the complex can be done very simply. - Cory [more]
Unread 07-11-2015, 14:39
spat's Avatar
spat spat is offline
QDriverStation Developer
AKA: Alex Spataru
FRC #3794 (WinT)
spat is on a distinguished road
An open-source, cross-platform Driver Station...
Hello!
During the last months, I have been working in a cross-platform and open source alternative to the FRC Driver Station. Currently, the application is able to run on Windows, Mac and Linux. However, I am also implementing a mobile version, which would work on Android, iOS and Windows Phone.
This driver station supports the 2015 protocol, however, I have made it relatively easy to implement different communication protocols, since I separated the UI and the Communication library into different projects.
While there is still a lot of work (and testing) to do, I would really appreciate if you could test the application and send me some feedback about it. As you may expect, code is always welcome.
Please note that the mobile version is still under heavy development, so for the moment there are no binaries/installers available. I will upload them when the application is fully functional and thoroughly tested.
By the way, you can drive the robot with a "real" joystick or with your keyboard
Links:
(edit) For everyone who downloaded the application before November 8th:
I strongly recommend you to download it again, as I updated it to include an auto-updater and fixed some bugs with the keyboard/virtual joystick.
Notes:
  • Both the mobile and desktop version use the same library to communicate and manage the robot.
  • In the desktop version, joystick input is done via SDL2. If you decide to test this application, PLEASE check how SDL maps the joystick (in the same way as you do with the official Driver Station). Avoid involuntary robot movements! If you are unsure about this, use the "virtual joystick" option before testing it with a real joystick.
  • This project is written in C++ using the Qt toolkit.
Greetings!
Unread 07-11-2015, 18:33
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Re: An open-source, cross-platform Driver Station...
This is awesome!. I love open source projects. When I get access to a robot on Monday, I will try it out on Windows, OS X, and iOS.
Unread 08-11-2015, 01:01
spat's Avatar
AKA: Alex Spataru
FRC #3794 (WinT)
Thank you very much for your interest in the project! You are welcome to try out the application on iOS, however, please note that the mobile version is still in the alpha stage:
  • For the moment, you will need to compile it by yourself. I have included the build instructions in the readme file of the repository.
  • Some features will be missing and you will encounter bugs in the mobile application
Unread 08-11-2015, 01:14
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
I'm speechless... this is awesome
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 08-11-2015, 01:57
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
I'm also excited to try this out on a robot. This should save my team a bunch of table space. That may seem like an odd thing to say, but our solution to the the problems of the driver station not running on Linux and E-stopping on spacebar has been to use twice as many computers, half for development, half for running the driver station. This should solve both of those problems.
I've successfully built and started the program on Ubuntu 15.04. For others who are trying this I would recommend the following command:
sudo apt-get install libsdl2-dev qtcreator && git clone https://github.com/WinT-3794/QDriverStation.git && cd QDriverStation && qmake && make && sudo make install
I tried installing the proper Qt development libraries piecewise without Qt Creator and I got to a place where it wasn't obvious what part I was missing, but Qt Creator must have depended on it because installing it solved things.
Unread 08-11-2015, 16:55
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
I'm not huge into code, so forgive my ignorance...
Is there any way that this could run on windows rt? The processor (ARM cpu) can't run .exe so are you going to turn this into a windows app or anything like that? Thanks.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 08-11-2015, 16:59
spat's Avatar
AKA: Alex Spataru
FRC #3794 (WinT)
AFAIK, I can compile the application for Windows RT. If so, I will upload a RT installer the following week.
Unread 08-11-2015, 18:59
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
This is awesome! I have worked on an Android driver station, but haven't had time to finish it. Your application looks like it can (or will be able to do) everything I need.
I'm working on an Arch Linux package for the desktop version, which I'll upload to the AUR, in case anyone wants to use it.
Unread 08-11-2015, 22:59
Dartmouth 2020
AKA: lopsided98
I finished the Arch Linux package (at the expense of the timely completion of my homework), available here.
Unread 09-11-2015, 21:05
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
I can confirm that it installs correctly. Awesome work.
Also Awesome work to you spat!
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 10-11-2015, 15:27
Sauce-ome Sauce-ome is offline
FRC #4388 (Ridgebotics)
Sauce-ome is an unknown quantity at this point
This looks really awesome! Do you know if the drivers station would work on the raspberry pi or would the pi not have the power to run it? If it could it would open up some cool opportunities.
Unread 10-11-2015, 17:35
spat's Avatar
AKA: Alex Spataru
FRC #3794 (WinT)
Well, it runs on Linux and it does not consume too much RAM memory (approx. 15 MB on my laptop). If the current version is too heavy for it, I could easily make a "terminal" version of it, as I implemented the code that communicates and manages the robot in a separate library. In other words, I would only need to write the UI/GUI part
You can live for yourself today, or help build tomorrow for everyone
Unread 10-11-2015, 18:47
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
I love this! Any advice for (potential) contributors?
Unread 10-11-2015, 19:24
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
Imagine if you could run this on the RoboRIO itself over ssh.....
My Github Repositories
Unread 10-11-2015, 20:10
spat's Avatar
AKA: Alex Spataru
FRC #3794 (WinT)
The way the communications between the DS and the robot work would make this relatively difficult. But, given the appropriate network configuration, you could drive a robot with another robot...
