Go to Post .. if everybody else is buying all the thingamabobs so they can practice shoving balls into the whatsit. Maybe what you really want is to buy thingys so you can build a practice whojidingle. Being the only whojidingle robot can be a real advantage come alliance picking time ... - ChrisH [more]
Unread 11-11-2015, 11:54
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Windows operating system for new team laptop
Our team for the first time is going to buy a windows laptop for the drivers station. It will be the primary coding laptop. It will interface with github. It will be 64bit windows.
Does anyone know which windows version?
How much memory?
I have a tiny budget and don't want to make mistakes.
Thank you in advance
Unread 11-11-2015, 12:00
Re: Windows operating system for new team laptop
Windows 10 seems to be testing out just fine for the Beta test teams experimenting with this coming season's software.
That's going to give you the longest supported OS life span.
More memory is always better, but look for the price breakpoint where more memory gets expensive.
16GB of memory will support you for a long time to come.
Disk space is usually fine with what they sell nowadays.
Better graphics cards are only necessary if you plan on using it for CAD work, but even then you can go with a lower-end gaming graphics card.
Unread 11-11-2015, 12:03
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Windows 10. It is the newest, and in my opinion, the best. (I have been using it since January as a Windows Insider).
I would get at least 8 GB of RAM, more if budget allows.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 11-11-2015, 12:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's good to hear that folks are having success with windows 10. I've also been messing with it for quite a while as an insider, and so far, I have no desire at all to move from windows 7 on my "real" computer.
Unread 11-11-2015, 12:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I recommend something with a Solid State Drive (SSD) and a full HD (1920x1080) screen, and 8GB or more of RAM. The SSD is a big factor, in allowing you to launch programs, start up, and reboot quickly. Also, since it has no moving parts, it is not as susceptible to damage as you are moving it around, if it gets dropped, impacted, etc. On laptops nowadays, I recommend a 1080 screen. 768 pixels in height is just not enough for modern day workflows. 1080 will allow you to see more lines of code at a time, and to get more on the screen. I recommend 8GB of RAM or more so you don't ever approach dipping into virtual memory space, which is much slower. By the time you load the OS, a browser or two, and some programs, it's easy to max out 4GB these days.
If you were really on a budget, you might consider this laptop. It's essentially the lowest priced laptop with a 1080 screen on the market currently. While it lacks 8GB of RAM and an SSD, those things can be added with a bit of work involved, however it does take someone technologically inclined to do it.
As a disclaimer, I have no direct experience with this particular laptop.
The good news is, you're in the right time of year for buying laptops. This is right when all the deals are to be found.
Unread 11-11-2015, 12:22
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
If you can swing $600, consider something like this:
http://www.newegg.com/Product/Produc...6551-_-Product
. durable
. easy to get parts for
. 8GB RAM
. SSD
. good screen resolution
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 11-11-2015, 12:33
. durable
. 8GB RAM
. SSD
A solid machine with good specs, but I'd be weary of shelling out $600 for a 3-year old refurb.
Unread 11-11-2015, 13:04
Rachel Lim Rachel Lim is offline
FRC #1868 (Space Cookies)
Team Role: Student
Rachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond reputeRachel Lim has a reputation beyond repute
. durable
. 8GB RAM
. SSD
Costco often has great deals on (new) laptops that in the past has rivaled prices I've seen for refurbished ones. I think they have something new on sale every week / 2 weeks.
It's $100 more than the laptop linked above, but they currently have the Lenovo Ideapad 500s on sale for $699 + $25 shipping. The sale ends 11/15 though.
Link: http://www.costco.com/.product.100226901.html?
Specs: 8GB RAM, i7, 256GB SSD, 14" screen (1920x1080), windows 10
If you don't mind replacing out the hard drive yourself or are okay with a regular one, and don't mind a 1366x768 display, they have the Dell Inspiron 15 5000 for $529.
Link: http://www.costco.com/Dell-Inspiron-...100232353.html
Specs: 8GB RAM, i5, 1TB hard drive, 15.6" screen (1366x768), windows 10
You can also get the same laptop for $429 if 4GB RAM is enough (http://www.costco.com/Dell-Inspiron-...100156017.html)
Their entire list is here: http://www.costco.com/all-laptops.ht...y=PriceMin%7C0
Unread 11-11-2015, 13:20
AKA: Steve Peterson
I'm a fan of those T series Thinkpads, as much for the ability to string them along through repairs as I am for the specs. My goal is to get something that can withstand some abuse.
Rachel's Inspiron idea (hi Rachel!) is a good suggestion too. If you swap the HDD you can recover ~$50 on Ebay for it.
Unread 11-11-2015, 16:21
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
I'm on Windows 10 now, upgraded from 8.1. But I'm only on those because my laptop switches to a tablet mode. Windows 7 is still a much better desktop system. You won't have driver incompatibility problems and it's a more intuitive desktop GUI.
Unread 11-11-2015, 17:03
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Oh you kids with your new fangled Win 7 Did steam powered XP go out of style?
to the OP
Win 10
I love my SSD drive, it makes slow systems fast. Samsung is my brand of choice. Buy new, the $19 you save on referb isn't worth it,
Sanddrag says 8 GB of memory. Good if you are doing CAD, for Labview/Java/it's our driver station, 8GB is overkill. So 4GB is fine.
I'm a road warrior, so I drive Lenovo Thinkpads. The current one is a T61. Old, but did you know that 16+ of them are on the ISS? This one has 17 months on it, some keys are starting to show wear.
You can buy referbs from a known dealer, but buy 2. When the first one dies (and it will) pull and slam the SSD drive into the new system. Then look again for replacements. Why yes, there is a spare T61 in my robot lab, thanks for asking. Actually there are two....
Your price point is about $300, that way when you buy two it's not an ouch moment.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 11-11-2015, 17:04
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Get a used t430 off eBay with an ssd 8gbs of ram and at least a 3rd gen i5.
Unread 11-11-2015, 17:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Our team is Beta Testing this year's LabVIEW and having no issues with windows 10.
Anyone looking for a laptop who is on a strict budget, I HIGHLY recommend arrow direct.
4GB will run LabVIEW quite well, and I run it on several labtops that have a pentium core 2 duo with no issues.
www.arrowdirect.com
I just priced a nice Dell I5 with 8 gigs of ram for $200. I wish I had the contacts to connect Arrow Direct with FIRST Choice.
Unread 11-11-2015, 17:37
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
Word of warning, be weary of Lenovo, as they are notorious for adding malware (like Rootkits and superfish,) which will mess with your usage on the internet and the data it takes. If you get one, make sure there is nothing out of the ordinary on it.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 11-11-2015, 17:47
MrForbes's Avatar
AKA: Jim
Apparently, it did not!
I'm a late adopter, I admit. I usually use stuff until it doesn't work well anymore.
