Re: Java Command Based Crash Course Concept
I don't believe that any our four robots' code was written from scratch. We have started with a "barebones" program that has a similar drive system to ours, then start adding on our particular design choices. This is actually a design decision that we usually do after the high-level design solidifies: what code base shall we start from? For Recycle Rush, we started with our own 2013 code, which had a tank style drive. For Aerial Assist, we started with a generic mecanum robot code from the internet. I was not involved in programming our first two years, but I'm confident Gixxy also started with working code rather than trying to write a robot "from scratch".
Tough to debug - the 'set' methods allow you to put breakpoints to figure out what code is causing change. This is particularly important in multi-threaded code. At the same time, I rarely actually put breakpoints in simple 'set' methods as a veteran.
Make the member variables immutable with the 'final' keyword and use the variables directly. Then it's fine from a pragmatic perspective. Grumpy people will argue about style, but whatever. I mean, it's not as bad as javascript, where anything can change anything, and you can pass a variable in where a functor should be and nothing stops you until it blows up 10 calls into the stack... Last edited by JesseK : 11-11-2015 at 21:52. |
I think this process will take one confusing step out of the equation for new programmers and teams without programming support and hopefully give them the ability to quickly get a robot up and running. |
