Go to Post I don't see why this is an issue. Robots are immune to the N1H1 virus. - JesseK [more]
Unread 11-11-2015, 23:33
mruprem's Avatar
mruprem mruprem is offline
Manjit Ruprem
AKA: Manjit Ruprem
FRC #1671 (Buchanan Bird Brains)
mruprem is infamous around these parts
Unhappy Mounting radial bearing 217-3246 (vexpro)
Hello world! I have little experience in CAD, and I have to design a mount for the radial bearing 217-3246. Please help!
Unread 11-11-2015, 23:36
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Mounting radial bearing 217-3246 (vexpro)
It's hard to help without a little more detail. What is the application for which the bearing is used? What are the requirements for the mount?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 11-11-2015, 23:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Here's some ideas to get you started. https://www.sparkfun.com/categories/261
Unread 12-11-2015, 15:41
AmiableVariable's Avatar
AmiableVariable AmiableVariable is offline
the ginger one
AKA: Hannah Fritsch
FRC #4488 (Shockwave)
AmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to allAmiableVariable is a name known to all
This is a pretty general overview of bearing mounts, hopefully it's somewhat helpful. If you would like some more targeted advice, some clarification on your specific project and CAD experience would definitely help The context of the overall design is important.
Does it need to be able to slide for tensioning purposes? Then a bearing block set in a channel is probably what you would want to design, or grab a predesigned one off the internet (to purchase later, if needed). Tensioning systems are a pain to manufacture and design, and require a lot of extra parts, so this usually only applies to drive trains.
Otherwise, mounting a bearing is pretty simple, and there are a lot of options. It can be made with sufficiently large aluminum extrusion, machined out of a block of metal, plate, or really sturdy angle brackets. Attachment methods could include bolts, pop-rivets or welds, depending your resources.
The main requirement for placing a bearing is a sturdy place to bore a hole that fits the outer diameter of the bearing (main body, not the flange). If the supporting material is thick enough, and the bearing happens to have a flange, you can add a countersink so that the flange does not protrude from the surface of the mount. Generally, it's also good to have two support points for each shaft, so there will be another bearing or a gearbox that shares the shaft. If there is a flange, it is usually easier to put it on the "outside" of the pair of supports.
In terms of CAD, what are you familiar with, and which modeling program do you use? It's possible to design many parts using just basic sketch tools, and extrude or rotate to add and remove material.
Last edited by AmiableVariable : 12-11-2015 at 16:05. Reason: Suddenly remembered that Solidworks exists.
Unread 13-11-2015, 00:38
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
This particular Vex bearing is an industry standard R3 size, available at lots of other vendors as well. If you want an non-Flanged sealed bearing it's a R3zz.
The Flanged version is a FR3zz. If you drop the zz suffix they are open bearings.
3/16 is a fairly small shaft size, be careful with the loads applied on that in your design.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 14-11-2015, 18:04
mruprem's Avatar
Manjit Ruprem
AKA: Manjit Ruprem
I need to mount the bearing on a bracket so that it can roll along length-wise along the bar. My problem is that I don't know how to CAD a suitable mount for the specified bearing.
Unread 14-11-2015, 18:06
mruprem's Avatar
Manjit Ruprem
AKA: Manjit Ruprem
What type of bearing might work if the load was to be approximately 15 lbs. distributed across 4 bearings?
Unread 14-11-2015, 19:48
InFlight's Avatar
AKA: Jim
Are you attempting to restrain a shaft moving lengthwise rather than in rotation?
There are both bushing and linear bearings that are suitable for this type of usage. Standard rotational bearings will not work.
You might look at McMaster Carr to get an idea of what is available and how you might mount them, search for "linear bearings"
IGUS (First Sponsor) has the Drylin R line that's worth looking at. (They give a discount for all First Team orders. Really first rate products and customer service in my experience.)
Unread 23-11-2015, 16:55
mruprem's Avatar
Manjit Ruprem
AKA: Manjit Ruprem
I'm trying to use the bearing as a wheel.
Unread 23-11-2015, 17:27
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
If that's the case, why not just use a caster or something similar? It won't be driven anyway.
An igus bearing will work, though.
Unread 23-11-2015, 17:45
wilful's Avatar
wilful wilful is offline
766 Alum &amp;amp; 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
Perhaps shoulder bolts will help
http://www.mcmaster.com/#shoulder-bolts/=zxuxzw
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 23-11-2015, 17:50
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
This, or, possibly, just a regular bolt. Sounds like you're in a pretty low-stress environment. The main thing I'd just point out is that bearings aren't designed to go over rough terrain, so you might want to avoid off-roading. A bolt and a bearing is probably fine (though a little sketchy) for light use.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 23-11-2015, 17:52
Chris is me's Avatar
AKA: Pinecone
I can't really tell from your descriptions and pictures, but are you trying to move something linearly along / inside an extrusion, like an elevator? In these cases, you'll need multiple bearings / bearing surfaces and can accomplish their mounting with two plates and a bolt going through both of them. It's a lot harder to do it inside of a tube compared to the bearings riding on the outside of a tube. Perhaps I'm not understanding you well.
