Go to Post If you squeeze cost out hard enough, any component can become a failure point. - EricVanWyk [more]
Unread 12-11-2015, 13:47
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: On being rude ...
Originally Posted by Lil' Lavery View Post
Asking for an answer to a question without searching or consulting the manual before hand can be rude or lazy. But a rude/lazy post doesn't mean you have to give them a rude/lazy reply.
For the record, I don't consider replies "Read the manual, the answer you want is in there, along with related important information."; or even the occasional "Read the manual." to be rude or lazy.
And, unless a close-enough-for-it-to-be-OK relationship between the two people exists outside of the topic at hand, I do consider "Read the manual, dipstick." to be rude.
With this in mind, I 100% agree with LL.
YMMV
Blake
