Go to Post You know you're addicted to FIRST when you text your mentors more than your friends from school. - LindsayC [more]
Unread 12-11-2015, 22:20
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Mind SensorMotor Controller for FRC
Has anyone considered the the coding impact by changing from the SRX to this new controller. The price point is very attractive. Also how do they work with encoders?
Unread 12-11-2015, 22:22
FRC #3944
Forgot to put the model SD540
Unread 13-11-2015, 03:19
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
The SD540 is just a pwm controller like the Victor SP. It doesn't have any option for connecting an encoder like the Talon SRX. You can download the manual here http://www.mindsensors.com/index.php...attachment=304
2016: FRC 865 Mentor
Unread 13-11-2015, 10:19
FRC #3944
One of the mentors on my team is an EE he installed a quadrature encoder on the SRX and he's telling me that I have to access it through the CAN BUS. Trying to get that working right now. Mman1506 could you please clarify your statement?
Unread 13-11-2015, 11:49
mman1506's Avatar
no team (WARP7)
The bottom line is that the SD540 has no ability to directly connect to an encoder or communicate over CAN bus.
Unread 13-11-2015, 15:35
FRC #3944
Thank you mman1506
Unread 13-11-2015, 16:03
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Mind SensorMotor Controller for FRC
Both this and the new Spark controller look like they can be used as a direct replacement for Talon SR with no change in programming (though there may be another class in the libraries). Each also supports both normally open and normally closed limit switches connected to the controller. Note that this information is NOT available to the RIO unless you also send it back to a DIO line. Neither supports CAN, encoders, nor potentiometers. As far as I can see with a casual reading of the specs, these two are functionally equivalent; the decision for one over the other will be based on quality, form factor, availability, and cost.
Unread 08-12-2015, 22:23
talon540's Avatar
talon540 talon540 is offline
Talon 540
FRC #0540 (Talon 540 Godwin Robotics)
talon540 will become famous soon enough
Talon 540, in a workshop, shot a short video of our robot running with SD540's. We will vouch for the quality of them given the performance in the video!
We used six: four for the mecanum wheels, one for the lift, and one for the pneumatic system.
The video is linked below:
http://youtu.be/9lq6U3EpTg
mindsensors, the manufacturer, is linked below:
Unread 11-12-2015, 13:32
talon540's Avatar
Talon 540
Also, temperature specs can be found here:
http://www.team540.com/sd540/
Unread 11-12-2015, 14:36
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
How could you possibly use a motor controller for a pneumatic system?
Jim
Unread 15-12-2015, 09:05
talon540's Avatar
Talon 540
I just realized... I need more caffeine! Apologies for an earlier post, but our robot does NOT use an SD540 for our pneumatics. It was for our lift mechanism.
Man, that's embarrassing. I'll drink some RedBull, wake up, and be quiet now. Sorry to Jim Wilks and FIRST for the confusion!
