Go to Post Find what your team is good at, and use it in any way you can. - karomata [more]
Unread 12-11-2015, 23:32
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
pic: Butterfly Drive
Unread 12-11-2015, 23:38
Chris is me's Avatar
AKA: Pinecone
Re: pic: Butterfly Drive
I would be very concerned the loads placed on a set-up like this, particularly in traction mode. You can't cantilever everything - when this is in traction mode, there will be quite the bending moment placed on the omni wheel output shaft. It's just an order of magnitude more load than a regular WCD output shaft would have to deal with since the module is effectively a very long moment arm.
Making a WCD-type butterfly drive requires a little out of the box thinking to carefully manage your loads and to ensure they are transferred through the chassis in a safe manner. Look at what 624's butterfly drive did as a good example. Also consider the possibility of the pivot module straddling the drive tube and using plastic slider blocks, etc. to transfer the loads placed on the module to the chassis directly.
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Looks good. The only things I am wondering about are:
Why did you choose to use the top of the module as your cylinder attachment point instead of the spacer closer to the front/back rail? Clearance issues?
Have you considered putting the screws for mounting the cylinder mount diagonally to each other or front/back instead of left/right in order to better take the loads from the cylinder?
What made you choose the double-omnis in the middle over a suspension?
Unread 12-11-2015, 23:47
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Wouldn't this be the best case scenario for this design since most of the force is transferred into the frame via the pneumatic cylinder? Or have I just been working too many night shifts?
(Awesome PPT force diagram below)
Either way, I don't think the lever arm for the bending moment on the cantilevered shaft changes since the force isn't any farther away from the frame rail.
Unread 12-11-2015, 23:48
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If I were doing grasshopper/butterfly with omni wheels, I would definitely put the solid wheels on the hard, fixed axis which would be better at handling scrub forces, and cantilever/actuate the omnis, which (by design), do not exert much scrub force. I understand the desire to gear the solid wheels lower, but I'd rather make that work by actuating the motors and gearbox and providing some slack in all the wiring than to pull the scrub force through a cantilever.
Edit:
Pneumatic cylinders should never be used to transmit significant forces except along the shaft axis. Solid wheels are going to be called upon for scrub (sideways, or into/out of the plane as you've sketched above) forces, especially in pin situations, and also in pushing matches. The pneumatic cylinder is not equipped to handle this force, and the parallel plates of a butterfly module are likely to "parallelogram" under this force. Exactly where this turns ugly requires more info than I have on your drive system, but at some point, you will have problems with the module hitting the side wall, a chain binding, or metal bending beyond its elastic limits.
Unread 12-11-2015, 23:59
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
When the robot is pushed sideways with its traction wheels down, the friction force resisting being pushed is exerting a torque on the cantilevered output shaft and that could be much higher loading than it'd see in normal operation.
--Madison--
...down at the Ozdust!
Unread 13-11-2015, 00:06
Robotics Engineer
Gah. Sideways. Darn non-ideal situations.
Unread 13-11-2015, 00:45
evand4567's Avatar
evand4567 evand4567 is offline
AKA: Evan
FRC #2022 (Titan Robotics and Team Neutrino)
evand4567 is an unknown quantity at this point
I'd recommend switching the placement of the omni and traction wheels. With butterflies, it's almost always better to have the tractions as the interior wheels as it reduces the distance between the wheels reducing wheel scrub when turning.
Mentor 2022 Titan Robotics, 3928 Team Neutrino 2015-present
Participant 2022 Titan Robotics 2012-2014
2014 Central Illinois Regional Semifinalists- 2081, 292
2012 Midwest Regional Champions- 16,148
Unread 13-11-2015, 00:52
Jack S.'s Avatar
Jack S. Jack S. is offline
FRC #0624 (CRyptonite)
Jack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud of
*snip* Also consider the possibility of the pivot module straddling the drive tube and using plastic slider blocks, etc. to transfer the loads placed on the module to the chassis directly.
We used this setup on our 2014 and 2014 off-season upgrade drivetrains to much success. It kept everything compact and supported, helping eliminate those pesky bending moments. We also used the same setup on our actuating perpendicular middle wheel in both 2014 and 2015.
Another thing to consider is where you place your cylinders. We were space limited in our 2014 drivetrain, so we tried mounting the cylinders directly to the top of our 2x1 side tubes. We were surprised to find that our cylinders still generated enough force to lift the entire robot off the omni wheels even at such an inefficient angle. Just a thought to maybe save you some space later.
Also, don't forget to think about your chain runs. If I'm seeing it correctly, it looks like you're wanting to run the "TexasTube" chain-in-tube style setup. If so, you might want to think about how your gussets for your center bar will attach to the side bars. Chain doesn't usually like to run when it has bolts or rivets getting in its way. Trust me, I've tried it before.
2013: 1539 Clover Robotics
2014-2016: 624 CRyptonite
Unread 13-11-2015, 00:56
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Depends on what you want. Some teams like the longer wheelbase so they don't get turned around as easily when hit on the corner.
Theoretically, the omnis are used for the majority of the match since that's when you technically have the most maneuverability.
Speaking from experience however, I agree with you, having traction on the inside can be super helpful when making precise movements on the field. I think it just comes down to preference.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 13-11-2015, 01:28
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
We use Butterfly on Team Neutrino and we really like it. As far as the point about pushing it down while being right above, I never really thought about the force required to lift the robot 30 pounds per pneumatic cylinder/piston, but I just really like the awesome low-rider effect (and the piston sound with it) Also, having the axle through the omni is REALLY nice in that you just have to remove 1 bolt if you need to change modules out
Also as far as the side impact forces, wouldn't the twisting/bending be directed to the side plates which would be held in the frame and restricted on how far they could flex? We used steel for our side plates which seemed to work well.
Check out our CAD/Info Page here and how we integrated them here (and a video of the pistons down here).
Feel free to message me with any questions
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 13-11-2015, 09:52
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
Just curious, wouldn't a octocanum drive be lighter and take up less room inside the robot while performing about the same as this butterfly? What about the butterfly makes it better than octocanum or is it just preference? I would like to present an octocanum or butterfly idea to my team but I have no real experience with either one.
Unread 13-11-2015, 09:54
philso philso is offline
FRC #2587
Yes. We had problems with this in 2014.
I recall that some of our modules twisted quite a bit from the side (static and impact) forces. We had inner and outer 2 x 1 tubes so our main axle would not twist. Our gears were between the inner tube and the module so we could tolerate quite a bit of twisting in the module. In the OP's design, the twist in the modules would likely cause them to bind on the chassis tubes. (I just noticed that Gus is writing about the same thing).
The design has to be done with serviceability in mind. It took about an hour of fiddling to swap out one of our modules since they essentially had to be assembled in place. 148's design worked as Runneals describes, requiring about 2 minutes. The OP may want to consider what happens to the sprocket and chain inside the tube when the axle bolt is removed and how the axle can be put back in.
The OP may want to consider removing or reducing the pocketing of the module plates due to the shock loads the module may be subjected to. Depending on what the upper structure is like, it may be possible to install the cylinders in the space between the modules. This would require adding something sticking up on the top of the module for the cylinder to push against.
Unread 13-11-2015, 12:10
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I'm interested in the side-to-side module design. How do you insure it puts enough force down onto the floor so that the wheels don't slide?
Unread 13-11-2015, 15:08
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The two systems would take essentially the same space. The differences:
  • The Octanum must be designed to transmit scrub forces from the holonomic wheels as well as the solid wheels.
  • When the holonomic wheels are engaged, just as for regular mecanum and 4-wheel omni:
    • The Octanum will be able to use 71% of the acceleration indicated by the Coefficient of Friction in the forward, reverse, left or right directions.
    • The Butterfly will be able to use 100% of the acceleration indicated by the CoF in the forward in reverse directions, but will not be able to drive in, nor resist, strafe motion.
Sorry, but I'm not at all sure what you're asking. What side-to-side module? What is "it"? Which wheels? Slide which direction?
