Go to Post A Red Ryder 200-shot carbine Range model air rifle!!! - dlavery [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Unread 13-11-2015, 16:59
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Pneumatics off board recharge packs
Originally Posted by Joey1939 View Post
I am also very confused by the pictured recharge pack. Not only is it not legal (must be controlled and powered by robot), but having tanks onboard the pack makes no sense to me. I am going to assume that your goal is to fill the tanks on the robot and that you started with the tanks on the pack full before connecting it to the robot. The air stored on board the pack will spread equally through out the system and drop in overall pressure. Then you would have to leave it connected with the compressor running until not only the robot was full, but also the onboard tanks. I believe that it would take an equal amount of time as without tanks to fill the robot, therefore it is unnecessary to have the tanks.
My guess would be, since it's not controlled by the robot (once again, <R69>), and thus not limited by the pressure switch, they fill those tanks beyond 120psi. They probably use that final pressure regulator to ensure a 120psi fill into their on-board storage.
