Go to Post Don't bash FIRST for what you do not know. - David Kelly [more]
  #106   Spotlight this post!
Unread 06-11-2015, 01:20
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: New Products for 2016: Speculation, Wants
Originally Posted by asid61 View Post
Because when I'm using 3/8" hex shaft it's very convenient.
Also I forgot to mention: 3/8" hex versahubs and sprockets! Or a 3/8" hex to 1/2" sleeve if that's not possible.
That bearing combo is likely too small to hex. I believe AM used to sell that bearing and it would "blow up". It's also probably the reason why it exists with a 1.125 od and not a .875 od.
R.C.
MadTown Robotics Team 1323
  #107   Spotlight this post!
Unread 06-11-2015, 06:30
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Originally Posted by Knufire View Post
SDP-SI should have any GT2 belt you could possibly need.
FYI: Automation Direct now offers belts and pulleys. You won't have any "out of stock" issues there and 2-day shipping is free for orders over $49.
Belts and pulleys
  #108   Spotlight this post!
Unread 06-11-2015, 09:37
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Belts and pulleys
I only see "L" and "XL" belts and pulleys. No mention of GT2, GT3, or HTD.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #109   Spotlight this post!
Unread 06-11-2015, 12:51
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Originally Posted by Mike Marandola View Post
If they are the same wheels that they had at IRI, they are pretty neat. There are two new compounds, a "one match" and "one event" wheel. Unfortunately, I forgot the exact durometers. The "one match" wheel was very soft and grippy so I would imagine it would be great for non-drive uses.
I saw those too--very nice wheels, and they had the same tread as their HiGrip wheels but with softer materials as you mentioned (blue and black compounds IIRC). However, I was thinking of uses in FTC as opposed to FRC, where the HiGrip wheel is illegal, or where damage to game pieces are a concern...hence, my personal want for "grippy" wheels with less aggressive tread (or no tread).
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
  #110   Spotlight this post!
Unread 13-11-2015, 11:41
Joining the 900 Meme Team
FRC #0079
I'm not gonna comment on pros/cons of hex...
But banebots seems to have relaunched their website with some new products including colson hubs with both 3/8 and 1/2 keyed shafts. (http://www.banebots.com/category/COLSON_HUBS.html)
They will even install them if you order the wheels that way. Pricing isn't bad. No comments on availability or quality though, haven't ordered any yet.
  #111   Spotlight this post!
Unread 13-11-2015, 17:16
Oblarg Oblarg is offline
AKA: Eli Barnett
That clamp hub is glorious, and reasonably priced.
We need more of that.
"The breakfast of champions!"
  #112   Spotlight this post!
Unread 14-11-2015, 21:10
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Two years ago I went to visit the BaneBots facility and drove back to my team with those exact hubs and wheels. They were amazingly good, we used the same set of 1 1/2" X 4" wheels with the 3/8" hubs throughout the 2014 season with ZERO problems. If you want to use Colsons, but don't want the hex axle for some reason, these are probably the best way to go.
http://www.angelbotics.com
Remember why you're doing this.
