Go to Post Hey, those kind of thoughts lead to thick rulebooks!;) - David Brinza [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 16-06-2014, 12:44
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Re: Driving Straight
Originally Posted by Chris Hibner View Post
You can use the encoders to emulate a gyro for driving straight. Here is some psuedo-code for how to do it:
heading = 57.3*(leftEncDist - rightEncDist) / trackWidth;
if (abs(driverTurnCmd) < turnDeadZone)
  if (headingCaptured == FALSE)
     desiredHeading = heading;
     headingCaptured = TRUE;
  turnCmdPID = PID(heading, desiredHeading);
  arcadeDrive(driverThrottleCmd, turnCmdPID);
else
  headingCaptured = FALSE;
  arcadeDrive(driverThrottleCmd, driverTurnCmd);
When we've done this in the past, it makes it a little smoother if you lead your desired heading with your turn rate. So instead of "desiredHeading = heading" in the above code, we've done "desiredHeading = Heading + robotTurnSpeed * leadFactor", where "leadFactor" is a calibration that you tune to make the stopping of the turn smooth.
I really like this gyro idea i will have to give it a try.
I am only going to be using this outside of auto. During auto we use a gyro.
The method i am trying now is to use a velocity control PID for each side. however it would be nice to have a slave/master configuration but i am not sure hot to deal with turning
Unread 16-06-2014, 12:55
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
For long uses of a gyro make sure to take into account the gyro's drift.
Unread 18-06-2014, 13:42
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
We've found LabView compensates fairly well for the drift. We usually see a few degrees per minute, which has been more than accurate enough for our matches. If you need more than that, you can extend the duration it uses to measure the drift.
Unread 08-08-2014, 04:45
lakecat's Avatar
lakecat lakecat is offline
Cat Expert
AKA: Tristan Thompson
FRC #2635 (Lake Monsters)
lakecat is an unknown quantity at this point
I believe that the CAN bus library has built in PID. All we had to do last year was set it to speed control mode and to read off the encoder.
Unread 13-11-2015, 11:26
mschwab013's Avatar
mschwab013 mschwab013 is offline
AKA: Matt Schwabenbauer
FRC #0291
mschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to all
else
I'm currently trying to implement a very similar system and was wondering if you had any recommendations for tuning the PID constants and the "leadFactor" at the same time
2013 Pittsburgh- Gracious Professionalism award, 7th seed, 6th alliance captian, quarter-finalist(291,3492,4601)
2013 Queen CIty- Chairman's Award, 39th seed
2012 Pittsburgh- 23rd seed
2012 Buckeye- 34th seed, 2nd alliance, quarter-finalist(291,1241,4085)
2011 Pittsburgh- 13th seed, 5th alliance, quarter-finalist(291,337,3504)
2011 Buckeye- 18th seed, 8th alliance, quarter-finalist(279,291,3496)
2010 Finger Lakes- 15th seed, 5th alliance, quarter-finalist(291,1507,1559)
2010 Buckeye- Chairman's Award, Imagery Award, Quality Award, 4th seed, 1st pick, 1st alliance, semi-finalist(291,1014,1629)
Unread 13-11-2015, 11:40
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
We used the gyro for driving straight for Auto and during the matches this year. The gyro is the easiest way to make sure you are going in a certain direction. We used the drive straight to drive to the step and drive straight to back up from the step. This way we did not knock over a stack of totes. We had a lance sticking out that we used for auto to move the recycle bins out of the way. If the driver turned while backing up it would move the stack. This function to drive straight back was a huge hit with the drivers.
The NavMXP had very little drift. We left it running for 20 minutes one time and had no drift. Way better than the old kit gyro. If you are trying to drive straight and you have a gyro why would you do it any other way?
Tim
Unread 13-11-2015, 17:48
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Its important to tune your gyro properly or you'll get noise and drift. 316 ran into this problem last year.
2015 MAR District Champions
Unread 13-11-2015, 20:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As with so many things, it's important to understand how much noise and drift you can accept. If you're only using the gyro for autonomous (15 seconds long) or to do short-term maneuvers (like backing up in a straight line without your probe knocking down a stack), you can allow significantly more drift than if you're expecting your "arena coordinates" mecanum drive to be stable through a full 2-1/2 minute match. If you're looking for full-match alignment and can't get it from your gyro or encoders, consider if your strategy puts you up against a wall or other well-defined feature of the field on a regular basis, and see if you can use that as an opportunity for a heading correction.
Unread 14-11-2015, 00:21
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
We never got it fully implemented in a competition robot, but we made code last year that would use the output from two ultrasonic sensors to detect the angle the robot was at compared to a flat wall. When we would click a button on the dashboard corresponding to which wall the robot was facing, it would automatically reset the gyro to the measured angle away from the angle of the wall (+/- 90 for side walls, 180 for back wall). This meant we wouldn't have to slam against a wall to reset the gyro, we just had to drive up to it at a not-too-shallow angle.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 19-11-2015, 08:59
Programming Mentor
AKA: Tim Easterling
We actually had our NavMXP gyro running for over 20 minutes with only 1 degree of error the whole time. The NavMXP Gyro has been one of the most awesome finds I have had for the years that I have been coaching. I did a little work to the code from NavMXP but I do not see drift specially in the two minutes of the game. Our auto went 12 for 12 at world championships and was about 95% the rest of the year. We turned and drove straight many times throughout the match. The old kit of parts gyro was a waist of time. I am tell everyone that I see that this one is for real.
Unread 27-11-2015, 23:33
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Here is a comparison based "drive straight" code example that doesn't use PIDs. It is handy for demonstrations, programming practice, etc. where you need to be able to follow along without getting wrapped up in more advanced functions (such as PIDs) useful, like it was said before, if the user hasn't taken basic calculus. Works like a charm, it may be a little sparsely commented, but just PM me if you have any questions.
FYI: Top encoder is left side, bottom is right side. This code makes the robot REVERSE at 50% speed. (I just pulled it out of one of our autonomous routines).
The .06125 constant is "inches traveled/encoder tick" (you will need to update this to accommodate for your drive train reduction between the encoder shaft and the wheels).
The 85 constant is the desired distance in inches.
You can import this vi code snippet into Labview.
Cheers,
Skye
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs
Unread 28-11-2015, 11:45
I've seen a number of FLL teams use an approach similar to what I attached. They will have three to five cases where they tune the coefficients or return hard-coded numbers. Sometimes the sensor is an ultrasonic sensor to follow a wall instead of two encoders. Sometimes they reset the sensors inside the loop instead of accumulating.
These approaches work pretty well if the loop runs fast enough. It gives them a piece to tune and once they gain a sense of how the control works, you can add storage and have both integrated and term-to-term error, and pretty soon you have a simple PID, or at least the portion of it that you need for that problem.
Since FRC robots take lots of space and infrastructure to run, you may find it useful to use a smaller robot to structure the code, then try it out on an FRC bot.
Greg McKaskle
Name:	From Clipboard 3.png
