Go to Post Mess up something important and you lose. Just like real life. - DonRotolo [more]
Thread Tools Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
  #33   Spotlight this post!
Unread 16-11-2015, 20:52
KeeganP's Avatar
KeeganP KeeganP is offline
AKA: Keegan
FRC #2059 (The Hitchhikers)
KeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of lightKeeganP is a glorious beacon of light
Re: Pit Structure Ideas.
We redesigned our pit this year with the main goals being ease of transport and ease of use, with aesthetics being a close third. We're very happy with the end result, especially when it cost us less than $200 easily. Can be setup to fit within 8x8, 9x8, 9x9, 10x9, or 10x10. Setup time is roughly 10 minutes, and it can be easily modified. I've attached a picture of the setup.
Corners/Connectors: http://tarps.com/chrome2.htm
Pipe (Conduit): http://www.lowes.com/pd_72715-1792-1...=1&Ntt=conduit
Make sure you get the same size pipe as you do connectors so they fit together...
The idea is that the splice connector allows you to build different length poles that connect together to create a total 8', 9', or 10' span, to accommodate every pit size you may encounter. We used (cheap) shower curtain rings (and zipties) to hang banners and awards. Overall we were very happy with this simple and cheap solution that will certainly last for years to come.
The Hitchhikers Team2059.org
2011 NC Regional: Rookie All Star Highest Seeded Rookie, 3459
2012 SCRIW: Champions, 2059
2013 NC Regional: Finalists, 2059 (Thank you 1539 and 2655!)
2014 NC Regional: Industrial Design Award, 2059
2014 THOR: Finalist, 2059
2015 Palmetto Regional: Gracious Professionalism Award, Finalists (Thank you 1533 and 1261!), 2059
2015 NC Regional: Industrial Safety Award, Engineering Inspiration Award, Winner (Thank you 1225 and 900!), 2059
