Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Unread 16-11-2015, 22:50
quillford quillford is offline
FRC #5924 (The Cat Machine)
Rookie Year: 2015
quillford is an unknown quantity at this point
Metric vs SAE hardware
We are a new team, so we can fully commit to one standard. Which one should we go with?
Unread 16-11-2015, 22:54
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Metric vs SAE hardware
10-32 and 8-32 nuts and bolts are what we use. they seem to be very common in FRC
2016 Central Illinois Winner. Curie Division finalist
Unread 16-11-2015, 22:57
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Since your location says CA, I'm assuming you will be building everything with materials that come in SI unit sizes. Most American teams additionally will have SAE hardware (if you need anything in the pits or whatever) and chances are you will see mostly SAE standards in the things you use (some FRC components are metric, but very few). I'd say SAE as your main system, though 271 usually keeps a very small box of metric stuff laying around in case we really need it. It'll be more readily available, probably cheaper, and more compatible with everything else you might use, including VexPro and AndyMark products (who use SAE hardware on most everything).
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Many of the parts you can buy from FRC Vendors, such as VEXPro and Andymark, sell most if not all of the parts in Standard units (inch). I would recommend going with this unit of measure.
Though it is likely most of your students will be using metric when they get into the work place (even in the America).
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 16-11-2015, 23:07
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
SAE is really handy because hardware stores stock it.
However, if you are able to order everything online, metric is generally cheaper for screws, bearings, etc.
So if you have the money to order everything and have enough machine tools to avoid AndyMark and Vex, go to metric.
If you have fewer than the maximum available resources and want to use Vex and Andymark parts, go SAE. Most likely SAE is better for you, especially if you live in SF.
Unread 16-11-2015, 23:23
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Depends on how old your mentors are. I'm in my 50s, I love the old fashioned stuff.
Unread 17-11-2015, 00:47
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
If you dare to mix hardware, be VERY sure to label metric and sae hardware/tools differently. Like opposite sides of the room. Paint metric tools blue and SAE red or something.
Hex keys are almost cross-compatible, but can strip bolts. Same for wrenches (though those usually are easy to tell what size they are). Nuts are not compatible but somebody will try... see troubles with swapping nuts on main breaker and old PDB lugs. You generally had to trash the whole PDB when that happened. (not sure if the new one is different?)
Unread 17-11-2015, 00:53
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
McMaster sells metric screws with a blue coating. On the rare occasion you have to use metric, go blue.
We paint our metric allen keys red, and imperial keys yellow.
Unread 17-11-2015, 02:50
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Agreed. Too bad that FRC/VEX/AM suppliers went SAE... So yes, you will be purchasing double the drivers/wrenches/etc. However, the positive side it is a great lesson on the power of a base 10 system!
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 17-11-2015, 07:17
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
I'm going throw a completley biased opinion in and say Metric.
We've been standardised on metric out of neceesity, but even then we've never had great dificulty with intrerfacing with AM/VEX etc. It's true you need a second set of tools for many things, but I've found that more than enough socket, spanner and allen key sets often come with both Metric and SAE sizes anyway.
Don't stress too much about mixing bolts, in fact, stripping out a screw head can be a very good leason in using the right tool - not just the one that fits! That being said, you don't want that to happen at a competition!
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 17-11-2015, 07:45
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
In addition to standardizing on a measurement system, I would also advise standardizing on a thread pitch for each size. A couple of years ago, we tossed out almost all of our 10-24 hardware. We're using 10-32, because of how much AndyMark makes use of this thread, but coarse threads for other sizes, which are certainly easier to get locally.
Unread 17-11-2015, 09:30
Chris is me's Avatar
AKA: Pinecone
Many, many American companies use SAE / Imperial units and parts. I wouldn't use the industry as a reason to make a decision one way or another - a well rounded engineer will have to learn both systems in either case.
In FRC, just because of all the COTS parts using SAE hardware and the overwhelming majority of teams using SAE hardware to build their robots, I see no reason to go Metric for hardware at all. For nuts and bolts, it's about the same price, and you will need some SAE hardware on your robot anyway, so if you go metric for the rest of your hardware all you end up doing is creating unnecessary confusion and chances for error.
Save yourself a bunch of time and standardize on 10-32. You'll need the occasional 8-32, 1/4-20, or 4-40 bolt, but you can almost exclusively use 10-32 hardware and really streamline things. Makes it easier to find bolts and tools, replacements, etc. without having to size anything.
For bearings, Metric bearings are much cheaper and more available, but FRC standardizes on SAE for bearings as well, so it's probably just easier to go with that. Especially considering a lot of FRC bearings are proprietary (hex / ThunderHex)
Unread 17-11-2015, 11:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Just don't keep M8 bolts & 1/4 bolts in the same place. Supply houses & hardware stores in the states still have a better supply of SAE than metric. Especially for things like taps & drill bits.
Unread 17-11-2015, 12:26
MrForbes's Avatar
AKA: Jim
Our local Ace Hardware store is the go to place for nuts and bolts and screws...and they have about ten times as much space devoted to "SAE" hardware as they do metric hardware.
Unread 17-11-2015, 12:37
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
The older Power Distribution Board for the cRIO used metric M6 bolts for the battery input.
http://www.andymark.com/product-p/am-0865.htm
Not to be confused with 10-28 fine thread SAE which is very close.
Personally robots should be like so many American cars:
Totally unable to decide what should be SAE and what should be metric
Gotta keep those tool and die makers in business somehow.
Seriously: rivets just get the hole close.
I once pulled down a pan on an Oldsmobile transmission and inside it was stamped Ford.
At some point I guess you use what you got.
