Go to Post The extra button could also just be a spare, but that's far less interesting than other possibilities, so let's keep speculating. - Caleb Sykes [more]
Unread 17-11-2015, 14:07
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: Delta Drill Press Belt? Aftermarket Part?
Originally Posted by Mr V View Post
No actually I meant a belt like this http://www.oreillyauto.com/site/c/de...&keyword=5l330 since it is a wrapped industrial belt. The automotive one will work in a pinch but the profile is slightly different between the industrial and automotive belts.
I picked up the one that exact one at lunch. I will try it out after work.
Thank you guys.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 17-11-2015, 14:17
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
You probably found a replacement by now, but this product might be useful for those who need a replacement. It's designed to reduce vibration on tools such as table saws, drill presses, and other power tools. (I use it on my table saw, and it works!) The best part is you get to make it as long as you need.
http://www.rockler.com/1-2-power-twist-plus-link-v-belt
"It's NOT Just A Robot Thing!"
