Go to Post I never cease to be amazed at the creative engineering employed by some teams. - Karthik [more]
  #136   Spotlight this post!
Unread 18-11-2015, 10:06
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: FRC Blog - Something New - Team 'Standards'
While looking over the design requirements for the standards this year, a student raised a good question. The requirements specify that the horizontal supports must have a diameter no larger than 1/2 inch. They specify diameter and to me that means that it has to be round, but they also say that the designs will not be inspected. To the student this means he can do whatever he wants as long as the vertical support is 1/2 inch OD. He has a clever design, but will it cause a problem to not use two round horizontal supports? Thoughts?
I would bring up the spec sheet, but with the new website changing the way all the old links work, I have to dig some more to find exact language and I never thought I would need to print it as it was available online.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
  #137   Spotlight this post!
Unread 18-11-2015, 10:25
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Workaround link
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
  #138   Spotlight this post!
Unread 18-11-2015, 10:32
I guess the issue comes down to the fact that the language says what I said before. It specifies diameter so I read that as required to be round. But what harm would be caused by a square horizontal support?
Andrew Basse
  #139   Spotlight this post!
Unread 18-11-2015, 10:53
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
While diameter is most frequently associated with circles, it is not exclusive to circles.
  #140   Spotlight this post!
Unread 18-11-2015, 11:49
Never heard any application other than circle, this is straight out of my Drafting text:
A straight line going through the center of a circle connecting two points on the circumference.
What other applications have you used?
Andrew Basse
  #141   Spotlight this post!
Unread 18-11-2015, 12:03
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Diameter can be applied to shapes that are not round.
Here is an interesting read on the subject.
Diameter, more generally, is the shortest distance between two parallel lines that touch the figure being measured. For figures that are not round, diameter can vary with orientation; major diameter and minor diameter correspond the orientations that give the maximum and minimum measurements, respectively.
Richard Wallace
since 2003
  #142   Spotlight this post!
Unread 18-11-2015, 14:55
I've always taught major and minor diameter in reference to ellipses, but the diameter part comes from the construction method of the ellipse, not the end shape. I haven't heard the parallel lines definition before. I might need to read that book to learn some new tricks.
Andrew Basse
  #143   Spotlight this post!
Unread 18-11-2015, 15:50
The UK 50p coin is a famous example of a constant diameter figure that is obviously not round. It fills the space between two parallel lines 27.3 mm apart regardless of orientation.
Richard Wallace
since 2003
  #144   Spotlight this post!
Unread 03-12-2015, 23:28
igor@levymeiste igor@levymeiste is offline
FRC #2877
igor@levymeiste is an unknown quantity at this point
The links are gone on the FIRST site, or at least I cannot find them. Does anyon have the original document?
Thanks
  #145   Spotlight this post!
Unread 03-12-2015, 23:31
Ben Wolsieffer Ben Wolsieffer is online now
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Here is the blog post on the archive site.
  #146   Spotlight this post!
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Thanks
The old links work if you change www to archive
Blog Post:
http://archive.usfirst.org/roboticsp...team-standards
Standard Document
http://archive.usfirst.org/sites/def...s%20public.pdf
  #147   Spotlight this post!
Unread 09-01-2016, 10:06
abigailthefox's Avatar
abigailthefox abigailthefox is offline
FRC #1711 (Raptors)
Rookie Year: 2015
abigailthefox has a spectacular aura aboutabigailthefox has a spectacular aura about
Medieval theme=capture the flag+battle bots?????
  #148   Spotlight this post!
Unread 12-01-2016, 19:41
oliverchuckle oliverchuckle is offline
FRC #5416
oliverchuckle is an unknown quantity at this point
The main problem with a square is that i believe that the component that you use to attach the flag rod to the top of the drivers' station is actually a round hole. Making a square might cause the rod not to fit :/
You could however find some way to narrow it down so it could fit the hole, but even then theres a chance it won't fit too well.
  #149   Spotlight this post!
Unread 12-01-2016, 19:50
Daria Wing's Avatar
Daria Wing Daria Wing is offline
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
Daria Wing is an unknown quantity at this point
Our team has already started on our standard. Really excited about it because we are Dragons!! I say that it's a great opportunity to have fun while also being creative and professional. If you're having trouble with it, look up medieval standards and just incorporate your team into a simple design.
  #150   Spotlight this post!
Unread 12-01-2016, 20:04
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
lol
