Go to Post In the real world nothing is ever to spec. Just another part of the challenge. - Koko Ed [more]
Unread 18-11-2015, 14:55
quillford quillford is offline
FRC #5924
Rookie Year: 2015
quillford is an unknown quantity at this point
Building a robotics lab
We are building a lab for our new FRC team, and we need to give the architect cut sheets and measurements of the tools we will be putting in there. So far we have been looking at threads here and have talked to some local teams (4159, 254, and 2144), so we know the kinds of machines/tools we need but haven't looked at specific models yet. If anyone has cut sheets of these machines or recommendations, it would be super helpful.
The machines we're currently looking at getting are:
  • a drill press
  • horizontal and vertical band saw
  • CNC lathe
  • CNC Mill (we've already got one)
  • laser cutter (we're looking at the epilog mini 24)
Recommendations for machines/tools not on this list would also be very helpful.
Unread 18-11-2015, 15:03
AdamHeard's Avatar
Lead Mentor
Re: Building a robotics lab
CNC router before a CNC lathe or 2nd CNC mill.
Unread 18-11-2015, 15:04
FRC #5924
Rookie Year: 2015
Can you explain the difference? I thought a cnc router was just a mill for softer/easier to cut materials.
Unread 18-11-2015, 15:21
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
A CNC router is typically optimized for cutting sheets of material, and often has a larger space in that regard (for example, the ShopBot at the school 2667 works out of cuts 4'x8'x6" of material). They really are very useful, and high quality ones can cut through aluminum in addition to wood, plastics, or foam. They're really quite nice, and often have different use cases than a CNC mill.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 18-11-2015, 15:40
RoboChair's Avatar
AKA: Devin Castellucci
CNC router > CNC Mill > CNC Lathe
CNC router is the work-horse of 1678, followed by our manual mills, followed by our CNC 2 Axis Bridgeport, followed by our manual lathes. Then bandsaw, drill press, and chop saw.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 18-11-2015, 15:51
AdamHeard's Avatar
Lead Mentor
Since most FRC work is lighter duty cuts, it's a substantially larger work area which is easier to fixture sheet to. This lets you nest many gussets/plates into a single run easily.
Also, it's nice to take advantage of their long travel and build a long vice-style fixture for holding tubing so it can be machined quickly.
A good router can be had for $5k (if good discount), and $15k will get you something pretty solid for FRC.
You're going to have an incredibly tough time getting the same bang for your buck out of a CNC mill in that price range.
Unread 18-11-2015, 15:57
JB987 JB987 is online now
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
+1
Our ShopBot has been a tremendous help...for prototyping and especially when iterating components. In 2013 we probably made a dozen versions of our shooter plates.
"A genius is just a talented person who does his homework" T. Edison
Unread 18-11-2015, 16:03
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
I've been working on a home-made one, as a personal side project.
http://solsylva.com/cnc/25x25.shtml
Nothing to do with FRC, it started before I got involved with FRC, and mine was aimed at cutting wood and was never intended to be used for aluminum. The tolerances are probably nowhere near good enough for detailed robotics work.
Still, if I ever get it done, I wonder if my team would find it handy...
Unread 18-11-2015, 16:05
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
A manual lathe is very often more useful than a CNC lathe in FRC. Most FRC turning operations are just cutting stock to length.
2016: FRC 865 Mentor
Unread 18-11-2015, 16:06
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
I would personally suggest adding a CNC plasma cutter to your list. Great for sheet metal parts like gussets and belly pans.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 18-11-2015, 16:10
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Plasma cutters are pretty low tolerance and are generally for steel. I would probably buy a cnc router and a manual lathe then cnc mill. Those are my go to machines in the shop.
R.C.
MadTown Robotics Team 1323
Unread 18-11-2015, 16:12
mman1506's Avatar
no team (WARP7)
A good CNC router is far better than a CNC plasma cutter. A CNC router has miles better accuracy and precision. Aluminium is just not a great material to plasma cut, it has a strong tendency to warp due to its thermal characteristics.
Unread 18-11-2015, 16:15
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Adam, do you have any picture of your setup? I'm working on a new clamping setup for ours and I'm looking for ideas.
Unread 18-11-2015, 16:48
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Those of you who have purchased a CNC router, can you recommend your supplier or point of contact at the company. Thanks.
Unread 18-11-2015, 16:51
FRC #5924
Rookie Year: 2015
What kind of material should the router be able to cut? The ones I see mostly do woods and plastics and maybe aluminum.
