Go to Post After all, when any student is isolated because of a difference - because of race, gender, social beliefs, or ideological concepts - we all lose. - MysterE [more]
Unread 19-11-2015, 18:43
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: 3 cim shifting gearbox from 2471
Unread 19-11-2015, 18:44
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: pic: 3 cim shifting gearbox from 2471
Is this only supported from the chassis through those hex standoffs?
"The breakfast of champions!"
Unread 19-11-2015, 18:54
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Pretty nice.
Out of curiosity, did you waterjet the bearing holes and bolt holes in addition to the lightening pattens?
This past year, we only waterjetted the lightening patterns and outer profile, and then did all the mounting holes and bearing holes by hand with a mill (DRO!)
Unread 19-11-2015, 21:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I'm a little worried about those hex standoffs connecting them to the chassis, but apart from that it looks amazing!
How did you manufacture? CNC mill or something else?
Unread 19-11-2015, 22:35
AKA: CAAAAAD
Having experience with a waterjet, the rough(almost bead-blasted look) edges are pretty easily recognizable as being cut by a waterjet. At least I hope that I am identifying that correctly.
Unread 19-11-2015, 22:49
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Originally Posted by thinker&planner View Post
Pretty nice.
Did you cut smaller holes on the waterjet and then drill them with the proper drill size on the mill? or did you leave that section blank and then drill the holes?
If you water jet the holes to a smaller size then drilled them out with the proper size you could save time. You should do that on a drill press though so the drill bit goes into the center of the hole by itself. That's what I would do at least.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 19-11-2015, 23:26
AKA: CAAAAAD
For the #10 clearance holes, we left that section blank. For the bearing holes, we cut out like a 1" diameter hole so that we didn't have to center-cut with the bearing endmill.
I thought about making a center "pilot hole" for all of the bolt clearances, and I can't remember why we didn't do it. We certainly will in the future.
Unread 19-11-2015, 23:27
FRC #1836 (MilkenKnights)
We haven't had issues with just water-jetting the screw holes to the final size
Unread 19-11-2015, 23:42
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
They are part of the equation. But no, they are not its primary mounting.
Pretty nice.
We made multiple sets of plates with multiple different machining techniques. The ones pictured were waterjetted in their entirety. When the bearing wholes were too small, we brought them to size with a half round file.
The hex standoffs just reach around the 2"×1" rail of the wcd chassis and bolt to the bearing block on the other side. The two bolts to either side of the output shaft are also used the mount to the frame.
these plates were cut on a waterjet, but we have another set that was made on a mill.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 20-11-2015, 00:00
True, that should also just be water-jet cut. Bolt holes can be terrible.
2013-Present
2010-2013
