20-11-2015, 22:34
Technical Director
AKA: Gus Michel II
 FRC #3946 (Tiger Robotics)
FRC every-team canvas
This thread was created to build up a questionnaire for every FRC team, to be answered through pit scouting performed by a CD volunteer (or someone voluntold by a CD denizen). I'd like to keep this to at most twenty questions, answerable in about 10 minutes per team. Here's my initial cut; please recommend additional questions or options within the questions, or point out questions that you believe will produce unusable or meaningless results. I specifically did not ask about the team's total budget, because most team members (at least on my team) have no idea. - What's your team number? (does not count as one of the twenty)
- How many Pre-college Members do you have?
- Total number of members
- Number of "all-in" members (90%+ of build sessions)
- Number of "sporadic" members (50%- of build sessions)
- How many college or adult Mentors (includes Coaches) do you have?
- Total number of mentors
- Number of "all-in" mentors (90%+ of build sessions)
- Number of "sporadic" mentors (50%- of build sessions)
- Which of the following shop tools does your team have direct access to?
- Hand drills
- Hand-held powered saw (circular, reciprocal, and/or jig)
- Portable band saw
- Drill Press
- Chop Saw
- Table Saw
- Band Saw (fixed)
- Water Jet cutter
- Sheet Metal brake
- Lathe
- Mini-mill
- Manual Mill
- CNC mill
- Plasma/laser
- Other (specify)
- Which of the following sponsored manufacturing techniques do you have access to? If you know, about how many hours of each?
- Sheet Metal Fabrication
- Sheet Metal cutting (whether water, laser, or mill)
- Full milling of solid stock (manual or CNC)
- Other (specify)
- Do you contract any of your manufacturing beyond your sponsors? If so, which? If you know, how many hours (or dollars) of each?
- Other (specify)
- What is your team's top-level organization?
- one school
- multiple schools or school board
- community
- charitable foundation
- other (specify)
- Do you build a prototype robot? If so, about how many?
- Do you build a practice/twin/clone robot? If so, how many?
- How many (non-CMP, non-DCMP) events is your team competing in?
- Total Events from week 0 to pre-DCMP?
- How many of those events require your team to get hotels or other housing?
- How many require your team to rent a bus or buy group ground transport?
- How many require your team to travel by air?
- How many hours per week of combined build, practice, training, and programming does your team average (as a team or large group):
- between kickoff and stop build
- between stop build and first event
- between first and last event
- between your last event and the end of summer (Aug/Sep)
- in the fall (Aug/Sep to kickoff)
- How many "major sponsors" does your team have? Approximately how many dollars of donation (include labor at what you believe to be a fair rate) does it take to be a "major" sponsor?
