Go to Post I'm about to brain myself on a wall in frustration! - pfreivald [more]
Unread 21-11-2015, 00:21
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
pic: Wood Coast Drive V2
Unread 21-11-2015, 00:47
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: pic: Wood Coast Drive V2
I love the laser-cut plywood bases you guys build. I hope this works well for you, because I want to try it myself some year!
What size bed do you need for this one? ~3 ft squareish?
Unread 21-11-2015, 00:54
Mr V's Avatar
Mr V Mr V is online now
FRC #5588 (Reign)
Very cool, however one point, everyone knows that you need to make it red to make it faster
Unread 21-11-2015, 01:10
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Interesting design. Really like it.
Just one thing, why did you choose wood over aluminum for the drive chassis material? Is it for the weight benefits? I always thought that wood for a drive chassis is not preferable because when, say, you get hit by another robot, then the wood may break, or something like that. Really not sure of this, since I've never done so much woodwork in the past.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 21-11-2015, 01:58
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Really digging the black. Are you just staining black, or will anything be green?
What made you go with 12 fps single speed over something faster like 16-17fps or a shifting gearbox?
What is the overall weight for this model, minus electronics?
That battery mount is gorgeous.
Cound you post screenshots of the plywood wheel in detail? That in particular looks really interesting.
Unread 21-11-2015, 13:15
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Looking good, Cal!
It's mostly for convenience. We have a Trotec Speedy 300 (~29" x 17") laser cutter in our workspace that can cut up to 1/4" plywood. Since we have no CNC metal-working tools, the laser cutter is by far the fastest method to turn an idea into reality.
It's an excellent material, though, and surprisingly cheap. There are drawbacks (widening of side-loaded bearing and bolt holes, chipping, attachment method, etc) but we feel the benefits outweigh the issues. We may experiment with wooden gussets and aluminum tubing for the interface between the drive base and mechanisms, as well as the mechanisms themselves. While laser cut plywood is great, we like to stress that it's not always the right material for the job.
Unread 21-11-2015, 16:42
Custom User Title
AKA: Cal
Our laser cutter bed is 29x17", but parts up to 29x34" can be cut in two operations, one for each end, by opening the machine's door so the material can stick out.
-Our final color scheme is TBD.
-Gearbox ratios can be easily changed for free speeds from ~9 ft/s to >20 ft/s, depending on the distances normally traveled in the game. The chassis could easily be modified to use ball shifters, mounted like this.
-Excluding electronics and hardware not shown in the model and including motors and belts, the drivetrain weighs ~28.4 lbs.
-Images of the wheel can be found here. The only difference is that 6 dowel pins are used in each wheel in the album, as opposed to 3 in the robot's wheels.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 21-11-2015, 17:15
AKA: Brendan Simons
FRC #5406 (Celt-X)
When you decide to use plywood, do you do any calculations to guide your design? Do you use any of the formulas that civil engineers use for plywood (such as http://www.canply.org/pdf/main/plywood_designfund.pdf), do you use rules of thumb you can share, or do you just iterate until it works?
Are the captured nuts the only way you fasten the sheets, or do you glue them as well? Do you find the structure fails at the fastener typically, or some other way?
Thanks again for sharing
Unread 21-11-2015, 17:41
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Does the plywood ever warp over time?
Unread 21-11-2015, 18:53
Unregistered User
AKA: Kevin Forbes
Mostly we iterate Last year was the first with primarily plywood, so there was little worry about strength (no defense). We'll see if this year is different. Typically we just try to use good judgement on the placement of sheets. We didn't glue much on our last robot, but we're looking at gluing for tight spaces this year where we can't fit a captive nut. We have seen a few breaks near the slots in a recent side project.. better to learn that now than in 2 months.
It does, our space doesn't have much protection from the environment, so we get occasional warping after a few weeks. We're going to develop a jig to flatten the sheets in the cutter before build season. On the robot it doesn't matter much - if it's designed right, the warping disappears when constructed.
Unread 21-11-2015, 19:27
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
How well do these two operations line up? It must be virtually impossible to get a perfect seam with this, but I am guessing you can get them good enough?
I would not be concerned so much with X/Y lineup as much as Z rotation when re-jigging the part. Could lead to some wonky wheel misalignment
Unread 21-11-2015, 20:35
Necroterra's Avatar
Necroterra Necroterra is offline
Rookie Year: 2015
Necroterra will become famous soon enough
This looks great. Looks much cleaner and more open than last year's. Will there be a top plate or any cross beams? Also, about how many individual parts are there here? It looks like a lot less.
Are you planning to build one before build season for practice?
EDIT:
I can't speak for the team, seeing as I graduated last year, but I would assume that the flattening jig that Kevin mentioned would be a big part of making sure they line up. Additionally, plywood sheets are cheap, so if they can always cut another.
2015 Arizona East - Regional Winners, Creativity Award
Unread 21-11-2015, 20:45
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Originally Posted by Necroterra View Post
(...) Additionally, plywood sheets are cheap, so if they can always cut another.
If a CIM costs more than all of your combined drivetrain raw material, I guess you can afford to make mistakes.
Unread 21-11-2015, 21:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Everybody should know by now that red robots are unlucky, unless fielded by 1114.
Amen to that!
Unread 21-11-2015, 21:56
lewislongbottom's Avatar
lewislongbottom lewislongbottom is offline
Klein Bots 3735 Mentor
FRC #3735
lewislongbottom is on a distinguished road
How does attaching stuff to the robot work? It's probably a naive question, but I was wondering if using pop rivets is as easy as fastening them to metal? (I ask because I've never seen pop rivets used on wood before)
