Re: buying a lathe?
I know some people will be giving me flak about this, but seriously consider this one
http://www.harborfreight.com/7-inch-...the-93212.html Now before we start a flame war here, I want to mention the pro's and con's. The pro's Small easy entry machine Handles FRC shaft work just fine Can be equipped with a dial read out on both axes for around 50 bucks With a dial read out this lathe can hold 0.001" no problem(without pushing it) It comes with more set up tooling than you will need It is going to have a hard time severely maiming the operator The con's It is really only useful for Aluminum and plastic, steel takes some TLC to turn It does require more basic maintenance more regularly You are going to have a hard time doing large stock Most of the extras it comes with are difficult to work with or will not last very long I have used this exact model lathe to make parts for our competition robots and it is a very serviceable machine for smaller parts. If 1678 had no lathe and we could buy one of these and some choice extras on sale I would do it in a heartbeat. |
Re: buying a lathe?
Little Machine shop 7x14 on sale. You don't need 3 phase power for the smaller mills & lathes. Mr Forbes: Our South Bend 9 in is a mid 30s vintage. It has the single lever quick change gear box. Last edited by FrankJ : 24-11-2015 at 09:38. |
Re: buying a lathe?
Also, just a general tip. For almost any FRC turning work, and especially with (sometimes impatient) students (like me) running the machine, a three-jaw self-centering (standard 3-jaws usually have this) chuck will be way better than any independent-jaw chuck you can find. Sure, they might let you turn off-center work, and can be a bit more precise, but getting everything aligned is a huge pain, especially when most of your cuts will probably be facing operations or on-center operations.
Re: buying a lathe?
Thanks for everyone's response!
Our budget is $2000. We don't have a machining mentor, so I think our coach is more comfortable buying new. It looks like our choices are one of the around $1000 benchtop lathes like the ones at Harbor Freight or Little Machine Shop + tooling. Anyone have advice/warnings/experiences with these lathes? Btw, Little Machine Shop looks like a great resource, with their tips and guides. Looks like I have a long Thanksgiving Break ahead of me for research! Last edited by Chak : 25-11-2015 at 00:40. |
Re: buying a lathe?
Re: buying a lathe?
Look at the G0602. It has a good reputation. I would get a larger lathe before the LMS variety.
Quality Machine Tools has a good reputation for service and customer support: http://www.machinetoolonline.com/PM1030.html or http://www.machinetoolonline.com/PM-1127-VF.html would be a good choice. Don't buy a used one unless you consult someone who knows what to look for. A large number of old "good" lathes will be nothing more than a pile of headaches. I picked up a South Bend 10L and sometimes wish I hadn't since it needs about $1500 in work. That being said, when you find one in great condition that has been cared for, they will outlive you. |
#7
Re: buying a lathe?
Re: buying a lathe?
I'd find a way to make another few grand if possible (or skimp on tooling initially) in order to get a better machine. |
#9
Re: buying a lathe?
The only tooling you really need is some 3/8" high speed steel (HSS)/Cobalt blanks, and a parting blade. A boring bar would be nice as well, but you can make one with some round stock and a small 1/8" or so HSS blank. One of the quick change tool sets should have all of the holders included. Learn how to grind and all you need will be blanks, gages (for checking tip geometry), and a bench grinder.
#10
Re: buying a lathe?
Re: buying a lathe?
Re: buying a lathe?
To elaborate, to buy a new, reasonable quality lathe that will last (something in the 13x40 range), you're looking at $5,000-10,000. Ideally you'd find one that is Taiwanese made and not Chinese made (the latter will be at the lower end of that price spectrum).
#13
Re: buying a lathe?
I've been quite pleased with my PM-1127 VF in my home shop. The fit/finish is significantly better than what you'd get from something of the Harbor Freight variety.
We're actually having the same discussion on our team regarding a lathe. The other mentors would like to have something in the school shop just to cut spacers to length, and maybe turn an end down now and then. We could get something to handle that for <$1000, but the next $1000-$1500 buys so much more lathe. I know the $5K+ range gives you better material removal rates and the ability to handle even longer/larger stock, but so far my $2.5K home lathe has served me well. Last edited by Steven Smith : 25-11-2015 at 17:23. |
#14
Re: buying a lathe?
It's definitely nowhere near as good as the Monarch and Hardinge lathes I've used (it's not as powerful, of course, so I generally only take 0.05" cuts if I'm not parting), but it's worked out alright for me. Last edited by LisaGinkgo : 25-11-2015 at 22:41. |
#15
Re: buying a lathe?
