Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 24-11-2015, 15:48
riftware riftware is offline
Parent Mentor
AKA: Andrew Chandler
FRC #0031
riftware is an unknown quantity at this point
Re: Using encoder with talon SRX
I think I had found my problem - I am using the 2016 version of Robotbuilder I built from source (yay talon srx now works!) - I hadn't noticed when I threw the button in that it defaulted to while pressed not when pressed.
Originally Posted by ozrien View Post
If you are using RobotBuilder then you can to a "whenPressed" action...
https://wpilib.screenstepslive.com/s...e-to-a-command
If you are using command classes yourself there is a Button class you could wire into the scheduler.
If you are just writing straight java, I usually just copy/paste the following...
//instance variables
    boolean [] btns  = new boolean [] {false,false,false,false,false};
    boolean [] last  = new boolean [] {false,false,false,false,false};
//get latest
    public void teleopPeriodic() {
        btns[1] = _joy.getRawButton(1);
    	btns[2] = _joy.getRawButton(2);
    	btns[3] = _joy.getRawButton(3);
    	btns[4] = _joy.getRawButton(4);
    	if(!last[3] && btns[3]){
    		//btn3 just pressed, do something
// bottom of teleop save all btns into last
		for(i=0;i<last.length;++i)
			last[i] = btns[i];
