Go to Post It is crucial to keep experience and keeping collected under pressure as high points that can't be measured in a test. - jnelly [more]
Unread 24-11-2015, 15:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Show off Your Machining! 2014
Originally Posted by marshall View Post
Can you describe the machining operations for this? What size bits were you using? What cutting speeds and feeds? How long did the machining process take?
Looks like it was water jetted.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-11-2015, 15:14
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Nothing crazy machining wise but this assembly was designed and machined in just over 2 hours. The delrin bushing was machined in that time too. I was pretty proud of how fast we were able to iterate our design in 2015.
https://scontent-lga3-1.xx.fbcdn.net...94&oe=56F1DEB7
2016: FRC 865 Mentor
Unread 24-11-2015, 15:28
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I can't tell anymore. I remember when waterjet produced distinctive edges but it seems like that's not the case anymore.
I'm eager to see where we end up in a year since we've added a CNC mill and lathe to our shop this year. Trying to get students to start using them this year and get shop supervisor more involved with the team.
Unread 24-11-2015, 15:37
Cory's Avatar
AKA: Cory McBride
It still produces a very distinctive edge. It's matte and speckled. Almost "frosty" looking
2001-2004: Team 100
Unread 24-11-2015, 15:44
Jared's Avatar
Jared Jared is offline
Here are a few pictures some neat parts/assemblies on our 15 bot.
https://goo.gl/photos/3S7NUVqLZMdKgeDZ9
https://goo.gl/photos/SVonUkqnnNMD18Py9
The second picture is of our elevator drive transmission, which was designed to be easy to swap out. The entire assembly is mounted on a 1/4" aluminum plate and drops out of the robot with three bolts. Then, the two pieces of square tubing can be unscrewed from the plate. The box on the left has a shaft coupler to allow the versaplanetary to be swapped quickly and the box on the right has a 10:1 worm reduction.
Unread 24-11-2015, 16:24
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
[IMG][/IMG]
This plate was in fact cut on a Haas CNC mill. Machining credit goes to wafertech, our generous sponsor.
Its possible that the white paper background of this photo is making the shiny edges seem dull.
As I was not the machinist on this project, I can't give you the exact numbers. But I was there while this was being made and I can tell you what I remember the machinist saying. Something like 5000 rpm spindle speed with 12 ipm feed rate. The bit was .25" two flute end mill, and I'm pretty sure it was HSS. They did the thickness of the .25" plate in a few separate passes.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 24-11-2015, 16:39
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Oh! I just thought the metal our waterjet sponsor used had a weird composition. He did supply us with free 7075 aluminum parts once though so it didn't seem that far off.
Why does it do that?
Unread 24-11-2015, 16:51
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
It's because water jetting doesn't rely on the water to cut, but rather the abrasive that is mixed in with the water. This means you'll get a more dull and speckled edge instead of the shiny edge like you would from an endmill or chop saw blade that relies on a sharp cutting edge.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 24-11-2015, 16:56
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
The water jet has very very tiny Sand particles in the water. If you go into a place with a water jet you will see pallets of sand. It uses a very high pressure (approx 60 000psi) to push the sand and water through a very small hole in a nozzle. The water/sand creates that weird edge because it is essentially sanding it's way through the metal.
Here's a video explaining it
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 24-11-2015, 16:57
Sperkowsky's Avatar
Thanks.
Unread 29-11-2015, 09:45
RonnyV's Avatar
RonnyV RonnyV is offline
All of the above
AKA: Ron Visser
FRC #4481 (Team Rembrandts)
RonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud ofRonnyV has much to be proud of
Our CNC machining and work isn't high tier complexity. We're working on a metric gearbox and shifter option. (Normal ballshifter and/or swerve shifter)
Here is some machining work from last season:
Unread 29-11-2015, 14:14
marshall's Avatar
Just use the other side of the ruler.
Nice parts though! I still maintain that you guys make gorgeous robots.
Unread 29-11-2015, 14:36
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
We asked for a 3" hole. Everyone was pretty excited when this happened.
-Hugh
ID:	19509  Click image for larger version
Unread 29-11-2015, 14:43
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Here is some machining work from last season: (...)
That sure is pretty. Is the last part steel/stainless?
Unread 29-11-2015, 18:47
RonnyV's Avatar
All of the above
AKA: Ron Visser
It's aluminum with brass IIRC, where the 2 vertical axles are stainless.
