pic: Butterfly Drive V2
Re: pic: Butterfly Drive V2
Did you add a foot gusset to the front rails you used the barrelnut on?
It looks good, but just a few questions and things to check if you haven't already:
I've never heard of a foot gusset before, but to me it sounds like one that has an L shape and can mount to the side of the boxtubing. I could do that, but probably not with those modules in the way. |
I don't have any CAD software on my computer, so all I can do here is guess from the perspective render. |
#8
The optimal angle for floor engagement is therefore the pressure angle of the gears, though small variations from this should not cause too much of a problem. I also see that doing this with belt or chain would not work; the key point is that the drive gear pushes down on the wheel gear to provide the basis for the normal force. In order to apply enough torque to the module, there would have to be a significant gearing up within the module. Last edited by GeeTwo : 26-11-2015 at 14:11. |
#9
Edit: As far as the design itself goes, I have a couple of comments. First, I'd highly recommend that you extend the hex shaft that goes through the vex clamping gearbox so that it supports the other side of the module as well. This will not only improve serviceability by making it far easier to access the e-clip but also make the module more stable against twisting. It isn't critical for the module to be solid against twisting because it won't see much of any load in those directions, but there's no downside to improving it and, at the very least, it will make the meshing between the 48T gears nicer. Finally, if you could put a standoff in the bottom corners of the side rails it would significantly improve the rigidity where you have the giant cutouts, though they still make me uneasy. Last edited by Greg Woelki : 26-11-2015 at 15:09. |
#10
Since you have a large bottom pan providing rigidity in it's plane, you can probably pocket the top and bottom surfaces of the two side tubes quite extensively to reduce weight. The inside surfaces of the side tubes and the front and rear tubes can probably also be pocketed. You can probably also pocket the middle tube quite extensively too. Quote:
What retains the bearings holding the ends of the shafts with the omni-wheels on the outside surface of the side tubes? How will your drive modules be built? What is the order of assembly? It looks like you will have to insert the hex shaft after you insert the module plates into the bottom of the side tubes with the omni-wheel and sprocket for driving the traction wheel "held in place by a third hand". Our modules from 2014 were like this and were really frustrating to work with, requiring two people working in very tight quarters to get them in or out. I cannot remember the details but 148's drive modules could be pre-assembled and formed a self contained unit. They could be swapped in about 2 minutes. I think they used a dead-axle. You may want to delete the pocketing on your slide-drive module with the two omni-wheels. You may also want to beef up the "ears" that the two green standoffs attach to and add fillets where they join the main part of those plates. What keeps the two plates from "sliding" relative to each other when the slide-drive is pushing your robot sideways? It does not look like the main shaft extends through both plates. The two standoffs will tend to twist the ears they are screwed onto. Can this whole assembly be made from a piece of tubing with the wheel bearing holes offset so that the wheels stick out the bottom of the tube? It could be much more rigid. It may also be helpful to extend the main shaft from the VexPro Clamping block through to the front side of the module and add a support that is attached to the bottom pan. The VexPro Clamping blocks are plastic and will deform more than metal, allowing your shaft to wobble from side to side a little. Will the slide-drive module twist the main central shaft so that the front end moves towards one or the other side tube? This is the same issue as with the drive modules in your original design. Be careful when installing the motor on the VexPro clamping block. One student ruined one or two of them by overtightening the screws. Since cap screws have a relatively small head, the clamping forces are very concentrated and the screw was pulled through the plastic, deforming it. The screw head ended up touching the mounting face of the motor. The hole in the plastic became a press-fit for the screw head and could no longer retain the motor properly. |
#11
For a 4" Vex omni wheel and a Vex 60 tooth gear (I guessed), this comes out to a requirement that θ be no less than 19.1°. If the gear is larger relative to the wheel or the coefficient of friction is less or the pitch angle is larger, the angle will increase. Also, I did make a number of simplifying assumptions, but the bottom line appears to be that unless the module rotates to a nearly vertical orientation, the greater the rotation angle the less the likelihood of slippage. I'm putting some finishing touches on a white paper (about four pages) that I'll post tonight or tomorrow. |
