I found this link to a 2014 motor curve spreadsheet which includes mini-CIM on this post. The front sheet lists the stall and free numbers and does some theoretical stats. Go the the tab named after each motor (e.g. MiniCIM) to find a power curve.
Edit: Ninja'd!
__________________ If you can't find time to do it right, how are you going to find time to do it over? If you don't pass it on, it never happened. Robots are great, but inspiration is the reason we're here. Friends don't let friends use master links.
