Go to Post FIRST robots definitely meet many commonly agreed upon definitions of robots. Some will disagree. Good for them. In my opinion, it's not worth arguing over. - Mikell Taylor [more]
Unread 25-11-2015, 10:54
Kaleb Dodd's Avatar
Kaleb Dodd Kaleb Dodd is offline
FRC #1114 (Simbotics)
Kaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond reputeKaleb Dodd has a reputation beyond repute
paper: Team 1114 2015 Code Release (Java)
Thread created automatically to discuss a document in CD-Media.
Team 1114 2015 Code Release (Java) by Kaleb Dodd
Unread 25-11-2015, 11:01
Kaleb Dodd's Avatar
Re: paper: Team 1114 2015 Code Release (Java)
You can also send us an email at controls@simbotics.org.
Unread 25-11-2015, 12:32
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
I like the Singleton pattern.
Unread 25-11-2015, 12:41
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
//FIXME: this is kinda horrible do an actual implementation
I think the only thing wrong with the implementation is the name of the variable. It looks like a hack at first, but in reality it reads as the best way to trigger a sensor reset upon arrival at the point.
Really nifty stuff in this code. Looks like that indexer code took a bit more to get done than we conjectured.
What units are typically used for things like DriveToPoint? inches, cm, etc, ticks?
That is a LOT of autonomous modes o.O
GitHub
Unread 25-11-2015, 12:52
Kaleb Dodd's Avatar
We started using Inches for drive movements this year. We convert the encoder ticks into inches using the ticksPerInch variable in SensorInput.
Unread 25-11-2015, 14:05
Jared Russell's Avatar
Taking a year (mostly) off
I love reading code for great robots with a high level of automation. You can tell just how much time was spent optimizing everything.
One question. I noticed in your autonomous driving code, you do some compensation for voltage level:
Vect output = new Vect(xOut*12.5/voltage, yOut*12.5/voltage);
Did you find that this made a significant difference in your application as opposed to just outputting xOut and yOut directly? It looks like you had both modes available, so you must have done some sort of comparison.
Unread 25-11-2015, 14:07
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty
The number of auto modes you prepared is impressive. The way your team codes is very similar to how we do things on 4901!
I'm actually interested in the same question Jared had as well.
John Fogarty
Unread 25-11-2015, 14:16
Kaleb Dodd's Avatar
The compensation for battery voltage is in an unused version of the driveToPoint method. We played around with limiting the output based on current speed and battery voltage to reduce wheel slip but we eventually settled on linearly ramping the output over time.
Unread 26-11-2015, 16:17
jgrindle's Avatar
jgrindle jgrindle is offline
Losing Sleep
AKA: John Grindle
FRC #5122 (RobOTies)
Rookie Year: 2015
jgrindle will become famous soon enough
This puts my Kiwis PID loop to shame. I love going through your Code, it's so clean and organized. If I had the chance to redo my code, I would make it similar to yours, but surprisingly mine actually works somewhat nicely. I may redo parts of it, and make it look more like this, but my biggest problem would be encoders on the wheels. I'm currently only using a gyro to fix problems. I find it fun to compare the two different ways of implementing kiwi drives. If I had the chance(and parts), parts of my code would look more like yours! Awesome Job!
FRC 2015 Season: Programmer, Electrical, PIDTuner, Safety Captain
FRC 2015 Off-Season: Programmer, CAD Designer, Driver, Drive Team Coach, Electrical, Mechanical, PIDTuner
Unread 27-11-2015, 22:19
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
Hi Team1114:
Thanks for making your code available. I would like to learn how your code works, but I'm totally confused.
I downloaded the file and unzipped its contents.
Next, I clicked on a bunch of folders.
Do I need a development environment to read the code?
Dave
Build Mentor
Unread 27-11-2015, 22:34
Kaleb Dodd's Avatar
The code was written in the eclipse IDE and would be best viewed from that program, however you can go to src>org>simbotics>simbot2015 and you will find all of our .java files which can be opened in any text editor but I would recommend notepad++.
Unread 28-11-2015, 00:47
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Thanks for sharing this! Amazing resource...
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 28-11-2015, 16:26
Pauline Tasci's Avatar
Pauline Tasci Pauline Tasci is offline
Rockets and Robots
FRC #3476 (Code Orange)
Pauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond repute
Thanks Simbotics for releasing this! Code Orange, 3476, is in the process of learning Java in order to use it for the 2016 season instead of our usual LabVIEW efforts. These really help us!
Team 3476 Code Orange- 2014-? ~ Head Mechanical and Design Mentor
FIRST Orange County 2015-? ~Regional Planning Committee Member
Beach Blitz 2016-? ~ Event Chair/Director
FIRST Volunteer-2010-?
Team 589 Falkon Robotics- 2010-2013 ~Captain, Driver, Outreach, Mech Lead
CD Moderator~ Always feel free to PM me.
Facebook
Unread 02-12-2015, 19:48
D.gimon D.gimon is offline
FRC #5324
D.gimon is an unknown quantity at this point
Why can I not download the .zip file??
From home it gets to the end and then says "Failed".
From work it doesn't even start.
Thanks in advance,
Dan
Unread 02-12-2015, 21:04
Connor McBride's Avatar
Connor McBride Connor McBride is offline
I live my life 2:30 at a time!
FRC #0166 (Chop Shop)
Connor McBride will become famous soon enough
This is really cool! Is the CAD file for your 2016 robot gonna be released to the community as well or no?
FRC 166 2013-2016 (student) 2016-present (junior mentor)
NHTI VEX U 2016-present (treasurer)
Youtube Channel Team Page Facebook Page
