Go to Post We're 30 pounds over LOL. I probably shouldn't be lol'ing, but it is 11:52PM, I just got home from a 15 hour build session, and I find the word 'potato' funny. - ZakuAce [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 26-11-2015, 11:13
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Second Robot for a Second Year Team
Apologies if this isn't posted anywhere else, but does anybody know if we get another control system in the kit this year? We want to build a second robot, but we don't know if we should or should not list the PDP on our Firstchoice list if we get another control system. From a couple posts here on CD, it seems that we may get another VRM, but not the control system. Other posts say we do. Any help would be appreciated (with a source!).
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 26-11-2015, 11:26
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: Second Robot for a Second Year Team
In the days of the crio I think you only got 1 as a rookie team. The crio is expensive. You could get them from Andy mark first choice after kick off some years I believe. The roborio is less expensive so we are hoping they will be available after kickoff on AM. Or you could buy one out right, about $500
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 26-11-2015, 11:52
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
According to the VRM page on First Choice, it will only be included in the rookie KoP; the same is true of the major other control items. Unless you can get one of the 1000 of each of these items (PDP,VRM, PCM) through FIRST choice, you'll almost certainly have to buy them. I'd put very long odds on the RoboRIO being in the veteran KoP, as well.
Last year, we held a piggybackr campaign to raise the money for a second control system so that we did not have to move the control board back and forth between the practice and competition robot (and use up about half of our withholding allowance). We raised a bit more than we needed in a month, mostly from family (including many extended family members) of students, alumni, and mentors.
Unread 26-11-2015, 12:05
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Have a look at this spreadsheet put together by Mark McLeod (He simply copied the info listed on the FIRST Choice product pages):
http://www.chiefdelphi.com/forums/sh...3&postcount=52
The column "KOP" indicates whether or not the FIRST Choice item in comes in the Rookie or Veteran KOP. To my understanding, veteran teams are not getting any components of the control system except for the new radio. Any control system components not listed in FIRST Choice are probably still up in the air, but my bet is that we won't be receiving them.
Unread 26-11-2015, 16:24
philso philso is offline
FRC #2587
Even if you will not build a second robot, it would be a good idea to get a second RoboRio. It can be used as a spare. We also rigged up a 12V supply using a 12V laptop power supply (other teams have used smaller wall warts) so that the software team could take the spare RoboRio and continue development work while a RoboRio was being installed and wired on the competition robot. They also took the RoboRio home to work on the software.
