Go to Post I love the smell of a upcoming FRC build season in the morning. The sleepless night; the drills; welding; cutting of metal. I wait all yr. for this. - midway78224 [more]
Unread 30-11-2015, 10:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
pic: CGX-108 front
Some dimensions are slightly different to allow for more clearance with the versaplanetary and take up error from machining, but it still fits right on and the external dimensions should match that of a VP.
Weighs 0.17lbs, about the same as or a little bit less than a VP gear stage.
Unread 30-11-2015, 10:14
End-Game's Avatar
End-Game End-Game is offline
AKA: Skipper
FRC #1339 (Angelbots)
End-Game is a jewel in the roughEnd-Game is a jewel in the roughEnd-Game is a jewel in the roughEnd-Game is a jewel in the rough
Re: pic: CGX-108 front
This Looks Very nice. I know I and my team would be interested in a 20-1 VP stage. Is this something that VexPro or AndyMark may make in the future?
We Don't Make Sense, We Make Robots.
If you can't find the time to do it Right, how will you find time to do it Over?
Mecanum, a drive system so graciously professional that it lets other teams drive your robot.
Unread 30-11-2015, 10:20
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Thank you. Probably not, but you never know!
Download CAD here:
https://workbench.grabcad.com/workbe...folder/1465067
Unread 30-11-2015, 11:46
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
I bet if enough poeple asked then they might consider it.
Correct me if I am wrong but wouldn't the center gear be wobbling?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 30-11-2015, 11:59
LCJ's Avatar
LCJ LCJ is offline
AKA: Lewis Jones
FRC #2468 (Team Appreciate)
Team Role: CAD
LCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really nice
If the Cycloidal stage is connected to another VP stage or the output stage, the output gear would be stabilized.
The stage by itself would be useless.
Unread 30-11-2015, 12:03
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Would love to seem them make this and see what it can do. Prototype it at least.
Unread 30-11-2015, 12:08
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
The two wobble plates are wobbling, but they wobble opposite each other around the axis (input/output shaft) so there is little vibration.
The input shaft has a shaft coaxial with the axle of the VP, and two offet pieces that hold the wobble plates. The shaft is 0.25" in diameter, and the shaft the wobble plates are on are 8mm, and the offset is 0.030". This allow the wobble plates to be put in, then the spline pressed onto the 0.25" shaft.
It should be able to connect to the output stage or input stage of a VP like any regular stage, I'm not sure what you mean. The output of the VP has 2 bearings that constrain it, and none of the ring gear stages have bearings on them.
Unread 30-11-2015, 12:31
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
How would the camshaft for something like this be produced? Is live tooling required?
Unread 30-11-2015, 13:13
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Probably. It's possible to do this with a 4-jaw chuck, but the time cost would be high enough to merit just using a 4 or 5-axis lathe.
It's also possible to do the input shaft on a mill, or make it in 3 pieces to avoid doing external turning on an offset.
Unread 30-11-2015, 13:36
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
For the non-engineering crowd, why would you want something like this? What's the benefit of this over a standard planetary?
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I think Anand should find a machining grant for the team to take on the risk of proof/prototyping. There's a lot of work in this CAD and I think the team would be very inspired to go through the process of proving a technically challenging design - especially one that's so tangible with respect to an existing product.
GitHub
Unread 30-11-2015, 13:38
JesseK's Avatar
FRC #1885 (ILITE)
Large reductions in a small footprint.
http://www.chiefdelphi.com/forums/sh...idal+gearbo x
GitHub
Unread 30-11-2015, 15:18
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Cool! It would be fun to see it built and what kinds of problems are encountered. The cam itself is kind of floating, there's not much to keep it co-axially aligned with the housing other than the cycloid wobble plates, but it looks like a good application.
It should potentially be stronger than a geared stage of a versaplanetary, given it's relying on a lot of pinned connections instead of a few meshing gear sets. If you stack to many stages of a versaplanetary the output stage can fail, since it sees a lot of torque. If you have a stronger stage, you can handle more load and get higher reductions before breaking things (not that you really need to... the versaplanetary system is already pretty solid).
Unread 30-11-2015, 15:33
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I'm looking into getting this manufactured. The wobble plates cannot really be machined manually, but I might be able to get the housing and output done on the mill. After that it's a matter of just getting the camshaft and wobble plates done on a CNC.
The input spline I might be able to do on a lathe by boring out a VP stage, but I'm not sure how to do the output. That would have to be wire EDM'd or something similar. I should send an email to Vex asking how they do it.
Unread 30-11-2015, 16:30
Munchskull's Avatar
Team Role: CAD
For the quantity they run it would not suprise me if they had a custom rotary brouch.
Anthony Cardinali
4th year of FRC
Class of 2017
