Go to Post On the other hand, if the tires were marked "NOT FOR FRISBEE SHOOTER USE" I'd be worried. - Ken Streeter [more]
Unread 30-11-2015, 17:26
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
BAG Motor at higher then 12v
Hello all,
Working on a fun project, hoping to use bag motors.
How do these do at higher then 12v, say around 15-17v (4S Lipo)?
Will be using current limiting controllers so they shouldn't be pushed that hard, and only need short duty cycles.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 30-11-2015, 17:36
AdamHeard's Avatar
Lead Mentor
Re: BAG Motor at higher then 12v
Originally Posted by Mk.32 View Post
Hello all,
It's the current that matters most (since the new voltage you're applying isn't all that much higher), so if you are cognizant of the potential for higher currents and handle it correctly you will be fine.
Unread 30-11-2015, 21:22
RoboChair's Avatar
AKA: Devin Castellucci
They work just fine at 18V, but you will wear out the brushes/commutator much faster than normal. The company I work at used them to drive our solar robots because I was familiar with them and the VersaPlanetaries. They averaged around 40 hours of continuous operation... we are now using geared motors that are $400 dollars each. I would advise you to put heat-sinks on them, should help prevent them from cooking as easily.
http://hobbyking.com/hobbyking/store...ize_motor.html
11 Years and counting! Over a third of my life has been spent with FRC.
