Go to Post I am thoroughly convinced FIRST is a sport. Convince me otherwise. - Bharat Nain [more]
Unread 30-11-2015, 18:57
Paul3161's Avatar
Paul3161 Paul3161 is offline
FRC #3161 (Tronic Titans)
Paul3161 will become famous soon enoughPaul3161 will become famous soon enough
Pneumatic cylinders Solidworks lessons
Hey CD,
I am trying to figure out how to calculate where I need to Place a pneumatic cylinder, to get the proper orientation I would be looking for. If I know the two dimensions of my cylinder, how do I figure out on Solidworks where it needs to be. Lets say it was a part of my intake from recycle rush, how do I figure out where the piston needs to be in order for my intake to grab the tote.
Thanks
Paulius Pace
Team 3161 Captain
Unread 30-11-2015, 19:07
AdamHeard's Avatar
Lead Mentor
Re: Pneumatic cylinders Solidworks lessons
This is how I like to do it; https://www.youtube.com/watch?v=8fQK6IWulSI
Unread 30-11-2015, 22:58
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Thanks for the video. And yes, I am a old engineer.
Unread 01-12-2015, 00:38
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Doing it with sketches as above is the fastest way IMO.
We like to download models of our cylinders from Bimba, as they come with all the features, including limits on the extension and retraction. This makes it very easy to tweak dimensions in the CAD to get it exactly where you want it.
Unread 01-12-2015, 00:44
AdamHeard's Avatar
Lead Mentor
That sounds a lot like iterating 2d geometry with 3D parts
Unread 01-12-2015, 13:05
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Adam, your video talked about what other ways to do something like this. The only thing I normally do different is I make things into Blocks, so the dimensions aren't in the way, and the relations don't mess anything up. It also makes it a lot cleaner and can make repetitive things quicker to draw.
Also I will sometimes start this sketch in an assembly, and then make the assembly using the sketch. A lot of the Part are 'In-Context" parts and everything will update when you change/modify your sketch. This is usually too difficult for a Student to do though, so I would only do this for school, or work (assuming co-workers know how to use in-context assemblies, so sometimes I'll break the references to old parts).
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 01-12-2015, 13:12
AdamHeard's Avatar
Lead Mentor
I need to give blocks an honest shot again, I used to over use them and they'd occasionally cause sketches to blow up. I'm not hearing that complaint from people recently though.
The second method I do a lot for personal and smaller projects, but I have trouble integrating on the team as so many different people of varied skillets work on the model and it tends to confuse them.
Unread 01-12-2015, 13:53
That's why I break the references when I'm done. It kind of ruins the whole "in-context" part but it makes Designing a lot quicker.
2013-Present
2010-2013
