Go to Post Robotics = my anti drug. - Queen_of_Mascot [more]
Unread 30-11-2015, 21:40
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Re: Throttle Motor
I remember seeing them on 2512's robot in 2013. I think they used them on the fly wheels that kicked the Frisbee from their ground intake to their hopper.
Unread 30-11-2015, 21:52
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
Re: Throttle Motor
Originally Posted by pilleya View Post
Hi I am a member of team 4613 Barker Redbacks, we have designed a low cost, low part count gearbox which gives the motor a 7.5:1 gear reduction, with a ½ hex output shaft. Our team has the capacity to manufacture these gearboxes in-house and we have partnered with a local sponsor. We are going to donate 40 of these gearbox kits to rookie teams in countries where it can be difficult to get parts like Australia, Brazil, Turkey and China among others. We will also spread the project to the FRC community by encouraging teams who have access to similar machining resources and distribute the gearboxes to teams in their area.
We have been in contact with Frank and he has confirmed that the throttle motor will be legal and sent out in the KOP once again in 2016(but with the FirstChoice release, we already knew this)
We have already made several systems utilising the gearbox we have designed, including a Polycord intake.
More information about the project will soon be on our website: www.team4613.org
This is pretty cool.
We had only thought of using them as speed encoders - similar to 1640. nice that free speed is about equal to a CIM.
If these work and it provides a use that teams can leverage, I am sure that all the throttle motors that anyone would want are available from the team community - for the cost of shipping. - nice re-use / recycle per the original intent I am sure.
Though it remains a low power motor and typically the transmissions are the cost driver not the motor....
(and 10X throttle motor power equals 1X AM-9015 motor power...)
Change is happening! - only throttle motors allowed! 30 throttle motor drivetrains!
Unread 02-12-2015, 18:19
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Throttle Motor
The throttle motor gearbox has been designed to be simple to integrate into robot designs, the gearbox shaft smoothly slides through the 1/2 inch hex hole in the gear assembly. This enables teams to use any length gearbox shaft they like, without having to purchase expensive couplers. The gearbox will be sent out with bushings, and it will be simple for teams to replace these with 1/2 hex flanged bearings if they desire.
Images of the prototype throttle motor gearbox design:
http://imgur.com/a/uJlaR
Unread 02-12-2015, 18:25
Ari423's Avatar
Happy Birthday! Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Throttle Motor
How are you dealing with the motor leads being inside the gearbox? I couldn't see any wires inside the gearbox to power the motor. Maybe I'm missing something.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 02-12-2015, 18:33
pilleya's Avatar
Elec+Mech
Re: Throttle Motor
Due to the gearbox design, there are many possibilities on how to power the motor. We have found spade connectors to be the most effective method of supplying power. These fit through the holes on the front of the gearbox, but the pins can also be bent at 90 degrees to supply power from the sides. Soldering wire directly onto the power pins works great too.
Unread 02-12-2015, 19:14
Ari423's Avatar
FRC #5987 (Galaxia)
Re: Throttle Motor
Ah. Now that you say that I see the little holes in the front of the gearbox. I wouldn't have thought they are big enough for spade connectors, but I guess looks can be deceiving.
2013: Programmer
Unread 02-12-2015, 21:09
sysdes sysdes is offline
Engineering Mentor
AKA: Maurice Veldhuis
FRC #4678 (CyberCavs)
sysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant futuresysdes has a brilliant future
Re: Throttle Motor
Yes, we did use one on our Recycle Rush robot at the IRI. We added the ability to pick up the 3rd can in order to manage a 28 point autonomous. The throttle motor drives a 3D printed sprocket on a hex shaft with a 10-turn pot mounted on the other end. We had fairly strong string wrap around the hex shaft and it had no problem lifting the can off the ground in less than 2 seconds. We did a 28 point autonomous a couple of times (see match Q4 of the 2015 IRI) The lifting mechanism was strong enough to lift the can right up sideways and bust the string (Q73) when our autonomous didn't complete properly. This messed us up big time and we scored 0 points for our alliance that round. Anyways, the throttle motor can certainly work and using a 3D printed gear to get a 15:1 gear ratio worked very well. I'm pretty sure the gear was strong enough to stall the motor without breaking teeth. You can see the 3D image here. http://www.cybercavs.com/throttle-motor.html
Maurice Veldhuis
Engineering Mentor, team 4678, Woodland CyberCavs
Unread 03-12-2015, 13:26
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Throttle Motor
Hi I am a member of team 4613 Barker Redbacks, we have designed a low cost, low part count gearbox which gives the motor a 7.5:1 gear reduction, with a ½ hex output shaft. ....
Have you considered making a provision for mounting two valve motors in the gear box? 2015 rules allow driving two valve motors of one controller. No reason to think 2016 rules would be different
