Go to Post I always viewed Gracious Professionalism as "I may not agree with you or even like you but we need to work together to solve this problem. So let's get to work!" - Koko Ed [more]
Unread 01-12-2015, 13:05
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Pneumatic cylinders Solidworks lessons
Adam, your video talked about what other ways to do something like this. The only thing I normally do different is I make things into Blocks, so the dimensions aren't in the way, and the relations don't mess anything up. It also makes it a lot cleaner and can make repetitive things quicker to draw.
Also I will sometimes start this sketch in an assembly, and then make the assembly using the sketch. A lot of the Part are 'In-Context" parts and everything will update when you change/modify your sketch. This is usually too difficult for a Student to do though, so I would only do this for school, or work (assuming co-workers know how to use in-context assemblies, so sometimes I'll break the references to old parts).
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 01-12-2015, 13:12
AdamHeard's Avatar
Lead Mentor
I need to give blocks an honest shot again, I used to over use them and they'd occasionally cause sketches to blow up. I'm not hearing that complaint from people recently though.
The second method I do a lot for personal and smaller projects, but I have trouble integrating on the team as so many different people of varied skillets work on the model and it tends to confuse them.
Unread 01-12-2015, 13:53
That's why I break the references when I'm done. It kind of ruins the whole "in-context" part but it makes Designing a lot quicker.
2013-Present
2010-2013
